Saxo immobilizer
Jonathancilia
- x 9
Saxo immobilizer
Hi, my saxo 1.5D is flashing the immobilizer on an occasion, when im driving only so far its done it, car keeps driving normally doesnt cut out. It does it rarely maybe once a month or so. Does this mean the immobilizer on the pump is going or maybe the arieal around the ignition lock needs replacing ?
- x 1055
Re: Saxo immobilizer
Can you confirm you mean the immobiliser light comes on when the engine is already running ?
Does it come on as normal for a second or two when you switch the ignition on the goes straight back off?
Jonathancilia
- x 9
It starts blinking like when you switch the indicator on, then when i switch off the car it doesnt come on again
Jonathancilia
- x 9
No issues whatsoever car still runs normally when it starts blinking. Car has 112000 kms and it has a bosch diesel pump
- x 1055
Most likely the aerial around the ignition barrel starting to fail. It will eventually give up completely.
£37.92 inc vat from Citroen, easy to fit & no programming needed.
Jonathancilia
- x 9
Ok so even if i fit one from another saxo from a breakers it will fit no programming needed?
- x 3296
So long as it is the same it will work. All it is is the aerial to allow the immobiliser system to 'talk' to the chip in the key.
Jonathancilia
- x 9
I found one on ebay brand new genuine part im going to buy it, its 33 pounds, sounds a good deal to me
Also will give peace of mind of not failing again like a 2nd hand one
