Could anyone share the part no for the little section of undertray that joins onto the main undertray at front and clips to along bottom of front wing (driver side).
thanks
Part no for trim undertray section
- x 5743
Re: Part no for trim undertray section
Let me know the item numbers for the parts you want the info for:
Thanks Marc, I did buy item 3, however mechanic said there’s nothing there to clip the bottom of the wing to? Is there a part that is not in that diagram that goes on the bottom of the front wings (the holes are there in the wing) but not holes in part 3?
- x 5743
Here is the front bumper detail - but with so many parts I can't help further without a photo really:
- x 5743
And here for the Wing:
It looks like it might be part 12 on the front bumper diagram. Can’t tell from the diagram of it has holes in for clipping to the front bumper directly under the front of the wing and then to the undertray ?
- x 5743
Item (12) is the Front Bumper Deflector: £40.28 Part No: 7414YA
Have a look here on this ebay link, it has better photos of the part with the holes so you can see:
https://www.ebay.co.uk/c/24014326008
Thanks Marc, been a great help, I think that’s the part, but the Driver side I need, is it different part no?
- x 5743
There's no separate part listed for left and right - so I suspect these are a set as per the diagram in my last post - which shows the 2 of them when the part is zoomed up.
