2007 C5 Xenon headlight retro fit
Kenmac15
(Donor 2022)
x 4
Unread post by Kenmac15 »
Does anyone know if I can swap out my halogen headlight units for the Xenon versions.
I know if I can that the lamps won't turn, but I wasn't sure if they're on self levellers etc
Ken
“I have not failed. I've just found 10,000 ways that won't work.”
x 6963
Re: 2007 C5 Xenon headlight retro fit
No is the realistic answer. You would need the headlamp washing system, updated washer bottle, bumper, rams and all that, headlamp ECU, wiring and software configuration BSI coding etc. etc. as well as the lamps and ballast etc.
daviemck2006
x 496
Unread post by daviemck2006 »
The xenons and associated stuff to go with them will cost you more than the car is worth, and you won't see enough of an improvement to justify it. I've had a few cars with xenons, including my current one, and the halogen units in my elderly rover 218d are better than the lot of them.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 3283
I would just go for high quality light bulbs and giving the lenses a damned good clean.
Kenmac15
(Donor 2022)
x 4
Oh yeah your all correct, I'll give that a swerve then
Ken
