x 8234
Re: Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
One has to be careful when soak-testing electronics..
Else this happens :shock:
Davies 'aquatic' HID Ballast
Hell Razor5543 wrote: 23 Jan 2021, 15:07
myglaren wrote: 23 Jan 2021, 15:04
Hell Razor5543 wrote: 23 Jan 2021, 14:42 I take it you are using a good quality contact cleaner to soak it in? :D
I said "contact cleaner", not "contact lens cleaner"!
I wonder if soaking in contact lens cleaner with improve the clarity of the audio? :lol:
After a few hours of running on the bench the radio continues to work well... Next job will be to reassemble it and see if it still behaves itself...
x 7995
CitroJim wrote: 23 Jan 2021, 17:28
I doubt it but at least you'll be able to read the labels more clearly!! :-D
x 8234
mickthemaverick wrote: 23 Jan 2021, 17:34
:lol: The labels in the set were no use anyway Mick, Google searches brought forth no useful service information for the set, just a user's manual...
I has hoping for a service manual but sadly there is no intention for it to be repaired...
x 1431
Unread post by xantia_v6 »
Are you sure that it was not an antenna problem?
x 8234
xantia_v6 wrote: 23 Jan 2021, 18:50 Are you sure that it was not an antenna problem?
No, because the fault was apparent on the bench before I dismantled it Mike...
And another radio works perfectly well in the car...
x 8234
The radio is now reassembled...
And it continues to work well on the bench :D
x 7995
You'll never get the bench into Daffodil unnoticed Jim! :-D
x 8234
mickthemaverick wrote: 24 Jan 2021, 16:42 You'll never get the bench into Daffodil unnoticed Jim! :-D
And if I did Mick, it would leave a big gap in my radio workshop :lol:
x 8234
Nothing to report on the cars!
Suffered a puncture during a bike ride yesterday...
Easily fixed :)
It was likely caused by a farmer flailing the hedges along a minor road I'd ridden about a mile before the tyre went down...
The flailing job was done very poorly and lumps of hedge were scattered all over the road... No attempt had been made to clear up :evil:
Despite that, it did noting to take the shine off what was a very lovely 30 mile tour :D
x 8234
On what was a very cold and frosty morning I ran 13.32 miles today, jut over a half marathon, to complete my RED (Run Every Day) January Challenge and to achieve exactly 300 miles ran for the month...
Sadly, Strava told me I only ran 299.96 miles 😥
When I looked at Garmin Connect - the software that connects directly to my Garmin Forerunner GPS watch - it told me I'd actually ran 300.1 miles :)
I fell victim to Strava's 'rounding down' when it pulls data from Garmin Connect... We call it the 'Strava Tax' :lol:
Here's my final January RED running distances:
RED January Challenge
Skull
(Donor 2026)
x 372
Unread post by Skull »
Well Done Jim =D>
Not as lucky with the weather lately ......ICEBERGS DEAD AHEAD :yikes:
Skull's Huffy
Skull's Huffy
Gary
x 7995
A great achievement Jim, you deserve a prize so how about this to fix outside your loo door: :-D
https://www.the-saleroom.com/en-gb/auct ... b500bd7104
x 8234
Thanks both :-D
Skull wrote: 31 Jan 2021, 15:02 Not as lucky with the weather lately ......ICEBERGS DEAD AHEAD :yikes: Image
:shock: :shock: You need spikes on your tyres ;)
The Arctic has moved south :lol: I noted a lot icebergs that were previously puddles in the beam of my head torch this morning... Some fleet of foot was needed to safely negotiate some of them!
Despite that it's been a lovely sunny but chilly day here today although in Somerset I hear it's snowing again...
mickthemaverick wrote: 31 Jan 2021, 15:42 A great achievement Jim, you deserve a prize so how about this to fix outside your loo door: :-D
That's proper cool Mick, I would love that :) And it's a proper four-aspect one too...
Green: safe to enter;
Double Yellow: Don facemask;
Single Yellow: Wear full respirator;
Red: Porton Down are on their way...
:lol:
x 8234
Todays little project: fit a DAB radio adaptor in Daffodil :)
First job was to install the aerial on the windscreen...
DAB 'film' aerial
DAB 'film' aerial
I pulled the A pillar trim off and hid the aerial cable behind it and hid it all the way to the head unit which resides rather neatly on the front wall of the centre console oddment tray...
Pure Highway 2000 DAB
The power and audio output cables I fed up behind the radio head unit and after cutting a small slot, fed them under the head unit cradle...
Power and audio cables in their slot
The radio head unit very conveniently has a USB socket to supply power to external devices that may be connected to it. Perfect for powering the DAB adaptor :)
It all works rather well and is about as neat as I think this sort of installation can be, given there is no aux-in socket or USB power on the rear of the head unit...
I know it's not in keeping with Daffodil's age but now I can listen to FM radio, DAB radio and stream Amazon music via Bluetooth :D
A good morning's work....
x 7995
CitroJim wrote: 03 Feb 2021, 17:15 Todays little project: fit a DAB radio adaptor in Daffodil :)
Mixed feelings about this one Jim, a nice neat engineering job BUT I can't go with the "because I can" straying from authenticity on this one. Did Daffodil actually give her consent for this modification? :shock:
