xantia rescue
Scottculli
x 29
Re: xantia rescue
Unread post by Scottculli »
hey Jim. this morning the weather has been dry so I took a good look at the break doseur to try and find the leak, it look as thought the top return pipe is the one that is causing the loss of fluid, I've been reading all the posts about how to try and fix it, and it says the best way is to remove the carpet and the bolts should be either side of the break pedal, the only problem is that the break pedal completely stopped me from getting my wrench to the bolt on the right, I was wondering if the was a trick that you knew off to get to the bolt as I cannot for the life of me see how to undo it, thanks Scott :-D
Skull
(Donor 2026)
x 380
Re: xantia rescue
Unread post by Skull »
Scottculli
I haven't had the pleasure yet but have heard most people say that they cut the bolt holding the brake pedal to remove it, then when they replace the bolt they insert it from the other side due to the clearance issues you are encountering .... good luck
Gary
Scottculli
x 29
Re: xantia rescue
Skull wrote: 21 Jan 2021, 11:29 Scottculli
To be fair drastic measures wouldn’t surprise me at all, I've been upside down all morning with my head in the footwell just trying anything it really is a peculiar design for sure, if nothing comes to me I could just try and snip the clip to the pipe with it still attached to the car and just work using my hands, thanks for the idea it gives me a option to try.
x 3296
Re: xantia rescue
You might also want to check the clip on the clutch pedal. They have been known to break in the past (especially if it is the older design). I believe (but I do NOT know) that the white/cream clip is the later design.
Scottculli
x 29
Re: xantia rescue
Hell Razor5543 wrote: 21 Jan 2021, 11:43 You might also want to check the clip on the clutch pedal. They have been known to break in the past (especially if it is the older design). I believe (but I do NOT know) that the white/cream clip is the later design.
luckily I've got an automatic, and I get a littlie more room to work with :) .
Skull
(Donor 2026)
x 380
Re: xantia rescue
Scottculli I believe it's designed that way to stop the bolt falling out and the brake pedal falling off .... I know what I'd rather :lol:
Gary
x 3296
Re: xantia rescue
I think it may have a nyloc nut on the other end.
Scottculli
x 29
Re: xantia rescue
Skull wrote: 21 Jan 2021, 13:05 Scottculli I believe it's designed that way to stop the bolt falling out and the brake pedal falling off .... I know what I'd rather :lol:
To be fair i can't disagree.who do they think they are designing things properly, to try and keep me safe :-D
x 8386
Re: xantia rescue
That bolt has possibly caused more blue air than any other on a Xantia :lol:
As an aside, I once did a 1.9TD clutch clip by lying upside-down in the footwell, whilst cursing and struggling with the bolt the driver's door closed on me and I was trapped :shock: I had to wait for my girls to come home from school to free me :lol:
They found it hilarious and so did I once I extracted myself...
Skull
(Donor 2026)
x 380
Re: xantia rescue
Jim That would have made a great ''You've been framed'' video and compensation for your trouble :rofl2:
Gary
Scottculli
x 29
Re: xantia rescue
CitroJim wrote: 21 Jan 2021, 17:51 That bolt has possibly caused more blue air than any other on a Xantia :lol:
hey it could have been worse, they could have just remembered what they wanted as a early Christmas present, on the condition of letting you out. :-D
Scottculli
x 29
Re: xantia rescue
Skull wrote: 21 Jan 2021, 17:59 Jim That would have made a great ''You've been framed'' video and compensation for your trouble :rofl2:
Something tells me for a fact that would be the most taped tv show in the house after that
x 8386
Re: xantia rescue
Scottculli wrote: 21 Jan 2021, 19:17 hey it could have been worse, they could have just remembered what they wanted as a early Christmas present, on the condition of letting you out. :-D
😂😂 They don't need to, even as adults they have me well wrapped around their little fingers 😂
Good job I love 'em!
Scottculli wrote: 21 Jan 2021, 19:28
Even I'd enjoy watching it again ;) :lol:
Scottculli
x 29
Re: xantia rescue
hey everyone i was hoping i could get some advice on the break problem I'm having, for the life of me I cannot see the solution or maybe there's just something simple that I'm missing, but the way to get it out is just is baffling to me. I can see the two 11mm nuts in the footwell the first one is simple enough, but when it comes to the second one I'm trumped, the break pedal stops me from fitting a wrench in there and the strengthen on the side stop me from getting it on a different angle, I was hoping that any of you that had tried this out before what was the procedure you used.
thanks Scott. [-o<
x 6945
Re: xantia rescue
Payback! Very satisfying to watch!
