Hi all my Peugeot 206 16v gti 2ltr start but does not want to idle so i spayed carb cleaner in the throttle and problem was solved for one drive but the same problem comes up .
Car starts but does not want idle .
Please advise
Peugeot 206 16v ltr gti idle problems
- x 1052
Re: Peugeot 206 16v ltr gti idle problems
Most likley a sticking idle stepper motor. Remove it & clean it but do not move the plunger by hand. Also properly clean the housing it sits in. Once you have cleaned & re fitted switch the ignition on & wait 30 seconds then switch of for 30 seconds, repeat this 5 times then start the engine.
