2014 Berlingo Rear Wiper Issues
Dave The Berlingo
Unread post by Dave The Berlingo »
Hi All
I have a really weird issue that has develpoed on my 2014 eHDi Multispace. My Rear wiper will only seem to work when the heated rear screen is switched on. Has anyone any idea on how i can sort this out ?
x 1055
Re: 2014 Berlingo Rear Wiper Issues
Unread post by wheeler »
You want to try a BSI reset first (do a search on here if you are unsure how to do this).
If this doesn't work i'd be taking a look at the wiring under the rubber boot where it goes between the body & tailgate, have a look for any broken/damaged/shorting wires.
x 6945
Dave The Berlingo
Hi thanks for the info, however on my 2014 Multispace, I can only see the positive battery terminal. How do I disconnect the negative terminal ? As it is unaccessible.
Cheers
x 1055
You dont need to disconnect both, one is fine.
