Sump'thing and nothing
mpr1956
- x 1436
When you put the car in low, the height correctors open and the pressure is removed from the suspension. However, since there is nothing pushing the wheels up they stay hanging in the air. For reasons I don't understand, when you re-start the engine and put it in high, the suspension doesn't repressurise, hence the falling flat you got. Secret is to jack it off the axle stands, then lower it so the wheels are touching the ground and the the height corrector is woken up, then stop lowering and wait for the car to lift itself off the jack - without crunching the sump.
- x 94
hi superloopy if you take the weight of a hydraulic citroen susp it de/presurizes usuly front end only but it either end are of ground with presure releast they done re/presurize untill weight back on sup some times xatias if rear end of ground with presure releast front end on ground when you put back on high before lowering rear to ground front comes back up then when you lower rear end it sinks right down then you have to lower front end to get it to rise fully ,you might of let your jack down to quick because you thout supsp was fully up when there was no presure in front system regards malcolm
oilyspanner
ActivaV6uk
- x 94
AndersDK
- x 1238
- x 1238
If the engine had been running and the system was pressurised, yes, but they sometimes take a while to come back when you have depressurised them. If you put the suspension on full height prior to depressurising, it will very often stay up as in this position the height corrector is overidden by the height selector
- x 1238
I just noticed the second part of your question. I live on quite a steep hill and also in the country, so what I have done is leveled the ground by the side of my garage and built a retaining wall about the height of a 45 gall oil drum. I have levelled the ground behind so that I can drive up to the top of the wall and have two thick planks of wood, supported by two oil drums onto which I can drive the car. I did this about 30 years ago and still have the same timbers in place! and they support my XM estate OK. This is just the right height for working on brakes, suspension etc and allows easy access to the underneath.
