Help please! Citroen jumper cuts of imidiately
- My Cars: Citroen jumper 2.2 hdi
So driving down the road I hear a noise like a sort of explosion and since then the car, once started dies in 4 seconds. While putting the foot on the acceleration pedal it works but it makes noise like when you run a car on Brake cleaner spray or start spray. So like there is no fuel. Checked the fuses all are okay. The diagnostic scan tool says malfunction in fuel pump circuit primary circuit. Also maf sensor. But I cant find the relee(fuel pump unit) location to see whether is the relay or the pump itself. Or maybe something else. Plus it's gone in antiteft mode probably cause the turn signal work even when the vehicle is off and ignition off.
