I have a dispatch van 2.0 07 plate and it has two issues that im looking to fix
1. Oil from the intercooler - anyway of testing before I purchase a new intercooler
2. Slow sluggish starting. The glow plug light comes on I can hear the relay clicking out and iv done a voltage test when I put on the ignition from the batter. The battery voltage (not started) shows good.
Iv attempted to find the glow plug harness plug to check if I can do a resistance check however I can’t locate it both times its rained on me.
Im sure they would have a harness plug? And im sure the glow plugs are right at the back. When I asked a dealer they both said glow plugs dont go on this model. Its done 94k
Your help would be much appreciated. Thanks in advance.
Citroen dispatch 2.0 07 plate slow starting
- x 3298
Re: Citroen dispatch 2.0 07 plate slow starting
It is possible the slow starting is due to a failing starter motor. I have had to replace one on an 04 C5, and helped to replace one on a similar age Berlingo. Assuming your van has an HDi engine it is very unlikely to have an issue with the glow plugs; it is so quick to start (even at low temperatures) the glow plugs are hardly ever used.
If it is the starter motor may I suggest you consider a refurbished replacement motor from GSF (certainly NOT ECP), as if you then return the old motor to them in the packaging provided you will get some money back. When I did so I got back about £60 (the original cost for a Bosch refurbished motor was about £120).
Oh,
to the Forum, by the way.
Oh,
Kal13
Thank you for that advice. Much appreciated
And thanks again for the welcome
JohnD
- x 72
My first C5 got reluctant to start from cold. Once it had been started, it was ok for the rest of the day. Eventually, I took it to Citroen and they said it wasn't turning fast enough to build the correct fuel pressure to start. A new motor solved the problem.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Kal13
Got an update:
My van only does the slow start on Cold starts
I took it to a starter motor company and they said this starter motor is of a good make and very rarely fails and if it does it wont last long. My issue has been for Years now Iv just lived with it.
The starter is a valeo make
I then took it to a diagnostic centre and they started taking about how much they charge per and would need to leave the van over night too. I am worried that I maybe left with a big bill yet no outcome. Its not that of a big issue just was thinking of getting it done.
The glow plugs are right at the back.
They said it could be fuel pump, timing belt?
So what Iv read in another post is to use battery pack in the morning and see if that helps start it fast or help the starter run faster. I my battery was replaced about 2 years ago. It starts even after a long 10-15sec of turning the engine over
Will see in the morning
Kal13
Started without any issues today with a battery pack?
Is it the battery?
Took it to Qwick fit and they said battery and alternator fine
Is it the battery?
admiral51
- (Donor 2026)
- x 392
Okay just going to throw my hat into the ring.
Assuming it is a HDi engine then glow plugs are probably only used when we are looking at sub zero temps, this time of year when it is a little cold they are not really needed.
Alternator can be checked quite easy, but as you have not stated a flat battery then it is charging as it should ?
It is an 07 plate so thinking logically, a battery is expected to last 5 years but if we say the first one lasted 7-9 years before it was replaced the my guess is the current battery is anywhere between 5-7 years old.
As you stated above it started fine with a battery pack i would replace the battery, not a cheapo ECP one but a decent one, much cheaper than putting it into a garage and letting them tell you XYZ was wrong
Colin
** Edit ***
Just re read but a 2 yr old battery can fail if a cell goes down
Colin
** Edit ***
Kal13
£200 for a battery!
admiral51
- (Donor 2026)
- x 392
You can a decent one for a lot less than that, you just need to look around and not take the first one you see.
If you have a battery pack on hand use it for 3 days and then try to start it on the battery and see if there is any difference.
I do not have access to find the correct rating for your vehicle battery, i am sure someone will be able to provide that info but gotta be worth a shot, cheaper than an alternator + labour charges etc etc
What is the current battery ampage etc, can you take a pic to show what it is rated at ?
Onlinemyglaren
- x 5678
Try: https://www.thebatteryguys.co.uk/ and https://www.tayna.co.uk/car-batteries/
There are many other battery suppliers too but these two seem to get decent reviews.
I got a Bosch battery for my C5 for £53+VAT.
- x 3298
I seem to recall that, on an HDi engine, the RPM needs to be at 800 before the injector ECU will command the injectors to put fuel into the cylinders. If, therefore, the starter motor does not get the engine up to the required speed fuel will not be injected, so the engine cannot start. Maybe the booster pack acts like an adrenaline shot to help an aged starter motor spin up fast enough.
What is the mileage of the van? On my 04 C5 it was around 200,000 miles and she would, when she was cold, sometimes take longer to start up, and it sounded slow. When the engine was warm she started more quickly, and the engine spun faster. Remember, a cold engine is harder to turn over than a warm one for various reasons (oil temperature and oil being spread around the engine rather than mainly in the sump).
Onlinemyglaren
- x 5678
Very similar symptoms to my C5 too.
Kal13
I took it to a starter motor company and they said thats a very good starter. If it was the starter he said it would have gone within the month
I tried it without the starter pack yesterday and it started okay?
I let it turn over then stopped it then put on the glow plugs till the light went out and then started ok.
The weather has improved. Im waiting for another bad spell of weather.
The battery I got is a Honda 780A CCA. 31500-SEF-E11-HE. 12v -77Ah
I did have to top up the oil too. I dont know if that could have added to the issue. But that was before this post.
I did read about putting more power to spin a bad starter. This issue has been going for years. Time and weather will tell. My pal wants the Halfords stater pack back next week. I think the starter pack kicked my van up the backside
- x 3298
I would then check the cabling to the starter motor. If there is a poor/loose connection that might cause your problem.
Kal13
I did feel it with my hand, like gave it a tug. What I will do is go round all the battery connections and The earth strap.
