I'm about to get round to sorting a few more things on my Dispatch. 2 drop arms and the anti roll bar. I've seen the anti roll bar repair kits, is there a make to go for or, more importantly, to stay away from? Same goes for the drop arms? I've used Stark for drop arms on the old 406 and they seemed to last.
Also I'm going to do an oil and oil filter change. I've had a look at the link here but the page doesn't seem to want to play. I'll be going for Total 5W30 but which specs? The van doesn't have a DPF but if it can use the same oil as my 407 and I can get a good deal for a bulk order I'd be willing to go for that as the 407 is due a change as well. Does anyone know the original part number for the oil filter please?
Cheers all.
Service parts help please
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Pete
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Re: Service parts help please
Hi Pete
Have a squiz at the following page on the wiki:
https://frenchcarforum.co.uk/wiki/Citro ... arbox_Oils
Find your engine code (DV6UTED4) from the relevant section and you will see under your engine code (9HU) the available oil types. As you can see this engine can take 5W40, 10W40, 0W30, or 5W30 oil. So which you actually use then depends on the climate (right back at the top of the page), so you can select the most appropriate grade for the conditions.
OEM Original Filter 1109AY: £14.84
Cheaper Equivalent: E149233: £8.15
Prices all VAT inclusive from Citroen as of today.
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2871
Lemförder and TRW are both good quality suspension parts 'manufacturers'. There are undoubtedly lots of other perfectly acceptable parts companies - and I'm sure someone will be along shortly with other recommendations, but if you can get genuine Lemförder or TRW at the right price, you won't go far wrong.
Sadly no longer a C5 owner
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Cheers Marc, so this should be fine for both the engines.
https://www.ebay.fr/itm/TOTAL-QUARTZ-IN ... Sw-v5eO-j4
and thanks for the filter number.
Thanks Bobins, I'll have a search.
Pete
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Just one last question (promise). Have you got the gates number for the accessories belt kit, (non AC, poverty spec)? I've got the cam belt kit along with cam and crank seals numbers but some reason never wrote the alternator belt kit down.
Pete
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Original Alternator Belt Kit: 1611278080 £167.62
Cheaper Alternative: 1613444080 £59.82
These include items (8), (9), & (20)
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Thanks Marc, much appreciated.
Ordered, 71 euros here, full Gates kit.
Pete
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries. Citroen OEM kits usually use quality Gates belts.
