hi all,
the good ladies partner B9 tepee seems to drain its battery after 4 days of not being used, i fitted a small solar panel trickle charger last year in a bid to help keep it topped up, but still seems to go, a little bit of research suggests the alternator diodes as the likely culprit, the alternator has never been changed in our ownership so figure its a good bet!
unfortunately for me, the sticker with all the information on is not there any more, the only numbers i can see are on the plastic moulding end cap are 2607196 and 2607197,its a Valeo unit, google reveals this to many variations of unit, the usual parts shops also list many options,
so something i have been meaning to do for a long time is donate to the club page fund as you have all helped me many times over the years,
if possible, could someone help with a part number ??
VIN VF3**************[VIN obfuscated, can be read by forum staff]
many thanks in advance,
Timmo.
Partner B9 tepee Alternator part number?
Timmo
- x 168
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 6962
Re: Partner B9 tepee Alternator part number?
There are several options for you:
Brand new OEM original, Part number: 5705NH which will be either a
Class 15 RL Bosch (01240AC1SB) or
Class 15 RL Valeo (TG15C118) or
Class 15 RL Valeo (TG15C134)
The above priced at £786.58
Then you have the cheaper variation:
Part: 1638095180 priced at £201.19 (plus a refundable exchange surcharge of £78.12) or
an OEM exchange, Part: 5702K9 which will be either a Bosch or Valeo part as described for the OEM above priced at £438.16 (plus a refundable exchange surcharge of £78.12)
All prices correct from Peugeot as of today.
Timmo
- x 168
many thanks Marc, you are a star!!
'58 C2 Code
'58 C2 Code
