Whatsthisthen?
Re: Whatsthisthen?
mickthemaverick wrote: 08 Nov 2020, 21:32 No I used my non google dark arts :-D The beach seems to be equipped with tanks for fuel maybe for Jetskis or fresh water for whatever you might need it for :?:
It was these structures I was thinking of Mick
odd beach structures
x 8126
Re: Whatsthisthen?
Yes they were what I was meaning, they look like high level gravity feed tanks to me. I wonder if they are the remains of a one time mulberry harbour or similar? :)
Re: Whatsthisthen?
I think this is the type of thing they are , not exactly but similar
Re: Whatsthisthen?
They are called Carrelets (Fishing Huts)
"Dotted along the banks of the Gironde Estuary are countless wooden fishing huts which have been built on stilts. Their main implement is a square-shaped pulley-operated net (or “filet carré”) which has given the humble shacks their name: “carrelets”."
https://invisiblebordeaux.blogspot.com/ ... -side.html
x 8126
Re: Whatsthisthen?
Yes indeed well done Neil, I found a picture of the ones offshore which are called "Cabanes de pêche"
BFTW
BFTW
Re: Whatsthisthen?
One of the places where there are a few free standing ones on the beach is here
http://www.didier-le-brestois.com/artic ... 44254.html
St Michael Chef-Chef on the coast across from Nantes
x 1463
Re: Whatsthisthen?
Unread post by xantia_v6 »
This one should not be too difficult.
Own photo
Own photo
x 8126
Re: Whatsthisthen?
A right hand drive small Simca? :)
x 1463
Re: Whatsthisthen?
You are on the right track, but a little more precision is required.
x 5672
Re: Whatsthisthen?
The location of the jack and the cooling system reservoir have a niggling familiarity.
Re: Whatsthisthen?
xantia_v6 wrote: 08 Nov 2020, 23:30 You are on the right track, but a little more precision is required.
Strugling with that one , haven't got that close. Not a single clue in that engine bay, no stray bits of wording or logos.
Four leads + 1 so I presume 4 cylinder in line maybe RWD, V4, or a flat 4 with the air cleaner in the V or on top but those things are rare in small cars. All injection or carburettor gubbins hidden.
Nothing green and round. Castrol GTX gets a mention...would the Italians or the French clag that on their motors?
So how close is SIMCA....very very or..is is just a small car.
x 1463
Re: Whatsthisthen?
It is a Simca-based design, but not badged as such, and probably not made where you would expect.
x 8126
Re: Whatsthisthen?
How about a Talbot Horizon built in Finland? :)
x 1463
Re: Whatsthisthen?
Not correct on either count, but on the right track.
Being RHD probably narrows down the list of places it would have been made as a CKD kit and then assembled elsewhere.
BTW, the Talbot Horizon was by some distance the worst and most dangerous car that I have driven in my life. Admittedly the example I had as a company car did have a braking fault, but the dealer could not fix it and kept sending it back with the same fault.
x 8126
Re: Whatsthisthen?
Then how about an Australian built Simca Aronde based CKD kit build? :)
