Lhd dual a/c doesn't blow heat at all. Tried methods: ac on, it blows freezing air. Ac off, blows the same as outside. Temp hi, still cold.
Diagbox gives no fault codes but shows passenger side sensor to be 6700c+some french text. Also pollution sensor shows high digits. I removed the glove box and flap gears, but didnt find the sensor. Can someone give me a repair document or some advice on this?
C5 X7 No heat to cabin
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5740
Re: C5 X7 No heat to cabin
What does your outside temperature display read?
If that is ok and there are no fault codes (which would rule out the heater climate control ECU, then I would be looking at the coolant system and the heater matrix.
Post up the French text your are getting too.
- My Cars: Xantia Activa 2.0 TurboCT, C5 Tourer HDI163 A 2012
Outside temp reads way too low. Is that connected to the a/c logic? Im going to do the diagnostic again today or tomorrow.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It does - but if it's reading too low, then I would expect the cabin temperature to be hotter not colder - so you'll need some investigation, Check the outside temp with a thermometer and replace it if it is way off.
Has the coolant been changed recently and if so, was it filled and bled properly?
Then I'd look at the outlet coolant outlet housing to make sure that is working correctly.
Turned out it was low on coolant lol. Don't know why though.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, keep an eye out then for leaks!
I'd look at hoses first of all, the head gasket area, the radiator for any nicks, water pump etc. Next time you come back from a run and the engine is warmed up, let it idle for a while and see if you can see any drips (but watch the fingers in case the fan kicks in unexpectedly....).
Didn't see any leaks after a test run. Oil cap had some moisture but i think it was just condensation. When i took off the coolant cap, it felt kind of loose. I think it may have evaporated over time because the previous owner didn't tighten it enough. I hope it was just that.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so hopefully that will be the reason. Bit it could also account for why the heating is not getting through into the left side of the cabin. If it's low on coolant and there is an air lock inside the matrix, then that could be the reason.
