C4 Grand picasso has poor acceleration on kickdown jumpy when changing gear gear box isnt slipping
this is the full auto gear box and not the egs version
Comments or thoughts please
C4 grand picasso 2 litre diesel auto poor aceleration
- My Cars: c4 grand picasso exclusive
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C4 grand picasso 2 litre diesel auto poor aceleration
I can't remember if you have Diagbox, but getting it hooked up and diagnosed is really going to be a must to be honest.
Most AM6 gearbox issue will have an associated fault code and seeing as there are over 120 possible fault codes you can see why it is important to get a diagnostic on it.
Are you having any gearbox warning faults?
Have you changed the Gearbox oil and if so how many changes has it had (bearing in mind you can only change 3 litres in one change as the other 4 litres can't be emptied from the torque converter). So it really needs at least 3 changes over a month or so to get as near to a full change as poss. And I'm also assuming the oil counter was reset after each change?
If you have and codes, list them up here and I can see if there are any specific issues.
It might also be worth checking with your dealer to see if there has been a gearbox ECU software update.
i dont have a diag box
the ATF has been changed once a few weeks ago ( it hasnt had the 2-3 changes as per previous dialogue )
It isnt coming up with any faults on the dash board , it is going in next week for a new CV boot so i will get a second oil change done then as well
i will ask about the oil counter
The garage are going to link it up to a diagnostic box to see if it brings anything up
keep you all posted
Thanks for the response
keep you all posted
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Make sure you get any and all fault codes when you do.
Absolutely essential that the oil counter is reset as this has a direct impact on the operation of the gearbox. The ECU accounts for oil deterioration over time and adjusts its operation accordingly.
Only the dealer will be able to see if there is a newer software update for the ECU, so bear that in mind.
Let us know the outcome.
Citroen Mansfield want £89 just to plug in a laptop to tell me if there is a software update
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes unfortunately that't the standard charge for connecting up their diagnostic Kit (Diagbox) - but the difference being they have direct access to the PSA servers that can query the ECU, check the database as to whether an ECU update is available and applicable to your specific engine.
Other non-franchised garages won't have access to this data, which is why the dealers charge as they do for this (as they have higher staff training costs and have to pay PSA for the leasing of the diagnostic equipment and all that).
