Hello.
2.0 HDi 2008 Citroen C5 (X7)
Just about to drain the coolant prior to new CB and water pump but can someone confirm the locations of the breathers for when I refill with antifreeze?
Thank you.
Joe.
Location of coolant system breathers
EJAP
Reason: Corrected Model & Year
- x 6947
Re: Location of coolant system breathers
Joe, pop up the VIN of this C5, as on the MK II (depending on engine) there were several modifications to the coolant system - specifically the coolant housing.
EJAP
Thank you Marc. It’s...
Cheers.
Cheers.
- x 6947
This is for a MK III (X7) not a 2007 MK II - have you given me the right VIN?
EJAP
Sorry. My mistake on original post. It 2008 Mk3 x7
J
J
EJAP
I’m typing on a phone. Sausage fingers!
- x 6947
Ok, I'll correct that first post....
EJAP
Thank you.
- x 6947
I've done a guide on this here in the resources section here for the DW10BTED4 engine on the X7:
C5 X7 DW10BTED4 Draining / Refilling Coolant
EJAP
Thanks yet again.
