Pollen fitter
Edcoats
Pollen fitter
Hi where is the cab pollen fillter on a citroen relay mk1 2006 2.2 hdi thanks
- x 6957
Re: Pollen fitter
You'll need to pop your VIN up so I can locate it - but if it's an early one then these are located in a box under the scuttle air intake. You'll need to remove the wipers and blades if it's this one - but I'll know for sure when I have your VIN.
