Peugeot 307 radiator fan
petarc1971
x 10
Unread post by petarc1971 »
The Peugeot 307 radiator fan turns on when I turn off the engine and runs for about 10min.It starts at a lower speed and then at a higher speed, the engine temperature is around 70 degrees c.
x 1459
Re: Peugeot 307 radiator fan
Unread post by xantia_v6 »
I assume that your model has a fan switch mounted in the top of the radiator. That could be fairly normal operation, or it could be that the switch has lost its calibration and is a bit sensitive.
You would need to measure the temperature at the switch (with an infra-red thermometer or similar) to work out exactly what is happening.
petarc1971
x 10
For tomorrow, I plan to clean the egr valve and to clean the drainage channels under the windshield, so I will look at what could be the cause of the incorrect operation of the fan.
