Dpf issue
- My Cars: Peugeot 3008 1.6 Hdi
Dpf issue
I have a peugeot 3008 and am having a load of issues with the dpf. In the last 6 months i have changed the injectors and seals, the maf sensor, handbrake switch and then the dreaded dpf light came on and wouldn't clear causing the asr light to come on. I have replaced the dpf filter for a new one and checked that the pressure pripes are clear, still the light comes on saying potential clogging. i have ordered the pressure sensor in hopes that is faulty. Has anyone come across this issue before and can guide me.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
Re: Dpf issue
There are a number of things it could be, but you need to arrange a diagnostics session first. Until you know WHAT the actual fault is you will be guessing, and possibly wasting money. Don't use a generic code reader, as it probably won't give you clear information (the PSA group uses proprietary codes that generic readers struggle with). You will need a DiagBox system to get full information. Some forum members have such a system, and may be able to help you.
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5647
Re: Dpf issue
When you replaced the DPF, did you use Diagx to inform the engine ECU that you have replaced the filter?LeytherAJ wrote: ↑04 Oct 2020, 18:00 I have a peugeot 3008 and am having a load of issues with the dpf. In the last 6 months i have changed the injectors and seals, the maf sensor, handbrake switch and then the dreaded dpf light came on and wouldn't clear causing the asr light to come on. I have replaced the dpf filter for a new one and checked that the pressure pripes are clear, still the light comes on saying potential clogging. i have ordered the pressure sensor in hopes that is faulty. Has anyone come across this issue before and can guide me.
Also when in Diagbox, you should be able to list any other fault codes there are (post them here) and also to see the live data that shows the pressure readings. That might help. You should also top up the diesel additive fluid and set the additive counter to zero.
Re: Dpf issue
i havent informed the ecu ive changed it i just thought it would know, i have a foxwell diagnostic reader can this be done on that or will i need to get someone to do it
Re: Dpf issue
thanks for the comments hell razor, i have used the foxwell reader that just show accumulation of ash and thats seems to be what triggers the other lights. i use the obd reader part and the generic
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Dpf issue
PSA vehicles ideally need Diagbox software with a VCI clone (often referred to as a Lexia Diagnostics Kit). The DPF itself is not electronic and contains no electronics, so there is no way for the engine ECU to know you have replaced it. There are of course pressure differential sensors - and these just measure upstream and downstream pressure to indicate clogged status. But as each regeneration occurs, these readings will rise before and the fall after regeneration.
You do need to tell it that the filter has been replaced, as the particle filters have a finite life and the ECU knows this based on rough mileage. With the diesel additive, the system does not physically measure the remaining content - it is just estimated from the original amount it was filled with, against amount injected into the fuel tank after fuel has been added. So again, when this is topped up (usually a good idea to do when replacing the DPF - the ECU knows that there has been no additive injected into the fuel tank and also that there has been no Cerine dumped into the particle filter (the unburnt part of the additive that always remains in the filter - which eventually causes the clogging).
So yes, very important to inform the ECU of both these operations. I don't know your diagnostic kit, so can't comment on its features technical abilities I'm afraid. If you get stuck and cannot find anyone near you on our list of diagnostic kit owners (link below), then a Peugeot dealer will be able to do this for you and will charge you diagnostic time to do.
viewtopic.php?t=56452
Re: Dpf issue
so the saga continues, i've now let the ecu know that i've replaced the dpf yet the light still comes on, I've got a pressure sensor that i will try next and see where i go from here. All i want is the light gone so i can get rid of this piece of junk.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Dpf issue
Without providing us with any diagnostic fault codes we can only provide advice on what you've told us so far. Having replaced the DPF without informing the ECU - completing this operation successfully is one less issue to deal with. There can be many other reasons for the warning light to be on, so if you have a diagnostic tool. run a complete diagnostic test and advise us of the fault codes.
If you are not getting any fault codes, then your diagnostic tool is likely not capable of communicating fully with all the vehicle's ECUs. A warning light (ASR) is an ESP related problem anyway and not an emissions related fault. Aftermarket diagnostic tools are notoriously bad at communicating with the ABS / ESP ECUs specifically.
An ASR (ESP) related fault that is generating a warning on the dash will have generated a diagnostic fault code logged int he ECU for sure. If you can provide the fault codes, I can probably give you some more pointers.
Re: Dpf issue
Hi Marc, what readings would you need to help me better specifically. i have taken a few screen shots of live data today to put on and see if you guys can help. i have replaced the pressure sensor since i last posted and have informed ecu of all changes but still having issues. your help on this is greatly appreciated
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Dpf issue
If you have a diagnostic tool, run a global test or equivalent and list here any fault codes being returned. If you are getting a warning lamp on in the instrument panel, but you are not getting any fault codes from your code reader, then I'm assuming you are not using a Lexia / Peugeot Planet 2000 / Diagbox, and are using a third party diagnostic?
Re: Dpf issue
the code i come up with id
P242F 07E8 DPF RESTRICTION ASH ACCUMULATION
this is the only code that appears.
thanks
Jon
thanks
Jon
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Dpf issue
Ok, so my thinking here is as follows - you'll have to correct me where necessary:
We know that at the time of replacing the DPF you didn't inform the engine ECU if the change. How long after changing the DPF was it before the warning light came on?
Do you know for sure that there is sufficient DPF additive in the tank?
I'm wondering that if the ECU thinks the additive is low, it may have disabled the additive function, which would of soon prevented assisted regeneration from taking place once the existing additive in the tank when mixed with additional fuel became weakened through lack of further additive being injected.
It would then not take long for the new filter to become clogged again. Once the filter gets to anything over 70%, regeneration may be impossible, necessitating removal and cleaning.
One thing we know is that regeneration has been stopped for some reason. If none of the above are the culprits, then it may be that the particle pressure sensor (s) as per the likely suspects in the table below, which may be giving false information to the ECU and this could be preventing the regeneration from taking place. In either case I suspect that the filter is rapidly filling, if it has not already become full, so I would strongly recommend not running the engine until the issue is resolved to avoid the filter coming off again.
Have a look at the fault code descriptors below:
I don't know the capabilities of your Foxwell reader, but I know some models can provide live data. If yours does, then take a look at the engine ECU and see what the upstream / downstream pressure readings are showing and what the state of the regeneration is / when the last regeneration took place etc. These may give us a clue as to the current status.
Fault Code: P242F Description of Fault:Particle filter detected clogged.
Downgrade Modes whilst Fault is active:
Suspect Areas:
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Dpf issue
One other thing - whilst I was checking your fault codes from your VIN - I noticed there is an outstanding aftersales campaign being flagged up on your vehicle!
Customers are usually informed during routine servicing, but if you don't use a PSA garage, then they won't be aware and so can't inform you. This usually happens when customers tend to do their own servicing or use an independent garage for servicing.
So I recommend you contact your dealer ASAP and advise them that you are aware of a an after sales campaign outstanding. They'll ask for your VIN and will confirm what the work actually involves.
From past experience with other members here with the DV6C engine, this may be relating to injectors / timing, so don't hang about.
Any work will be free of charge.
