Half my Dash Display is failing after 30/40 seconds of Key On.
I had the ECU tested = OK
Citroen C4 Picasso HDI
rwaterston
Re: Citroen C4 Picasso HDI
Hi
Mine is over 4 years old and its a known problem on C4 Picasso to dealers they have extended warrenty on them but mine failed to late to get this as not advertized
I have purchased another second hand one My replacement No (on mine) 9815286580 this No is direct replacement for alot of others ones .
Yo will need to check yours you will need no of rear and check with citroen see if your car fall within the £100 replacement scheme
