2013 DS5 Wheel nut Key
Bucknodd
Unread post by Bucknodd »
I've just got my DS5 and am missing the locking key for the wheels. Which is the correct one as there seem to be a few kicking about on a certain website and Citroen want £90 for a new one!
x 6950
Re: 2013 DS5 Wheel nut Key
2 Choices:
1) The keys are unique to each set - so if you've lost yours, then you'll need to get them forcibly removed and either replaced with another set or:
2) Remove them all and replace the locking bolts with standard bolts and do away with them.
Bucknodd
Thanks Marc, looks like a removal set and a new set are going to be bought!
x 6950
You can buy a standard set of special alloy wheel bolts for about £15 for 4 to replace the locking ones.
A tyre fitter may do this for you - requires drilling out usually if they can't get them off.
If you want a new set of locking bolts, have a look here - you may get some aftermarket or genuine ones for less:
https://www.ebay.co.uk/sch/i.html?_from ... s&_sacat=0
A set of genuine Citroen ones here for £42:
https://www.ebay.co.uk/itm/Genuine-Peug ... SwoSldjLE0
