x 5642
CitroJim wrote: 18 Sep 2020, 08:39
myglaren wrote: 18 Sep 2020, 08:26 Oooops!
Oh gosh!
Paint?
Yep. Been doing some work at daughter's while she is in hospital. Should have known better than to put opened paint tins in the car.
x 8275
Fingers crossed it will all clean up OK Steve [-o<
I'm sure daughter is hugely appreciating you decorating for her :D
x 8048
Ouch!! Hopefully that's water based paint Steve? :(
x 5642
mickthemaverick wrote: 18 Sep 2020, 09:03 Ouch!! Hopefully that's water based paint Steve? :(
Fortunately and luckily I have a wet vac for just such occurrences.
x 8048
A huge collection to choose from for this thread so I'll start with this one when it turned out the phone had the wrong camera activated :-D
Bob's work!!
Bob's work!!
x 7163
Another 10,000 post celebration :-D
Peter N has just passed the milestone. Watch this space, just need to be creative back in a Mo.
x 7163
NewcastleFalcon wrote: 18 Sep 2020, 15:39 Another 10,000 post celebration :-D
As I like to do, I have selected a page at random from all of Peter's posts. Struck a wordy page from 2010 so you will have to make your own pictures. I have highlighted the paragraph which caught my attention and which you may be able to visualise....
Peter.N. wrote: 16 Oct 2010, 10:07 Hi Ian
My estate has comfort spheres which I find quite acceptable but on the hatch rear the ride is a bit nautical.
My 5 series is an estate with rear air suspension which I understand does make the ride harder and is only comparable with the XM over rough unmade roads, otherwise not nearly as good a ride.
Tyre type and pressures can have a marked effect on the ride, unless I am carrying a full load I tend to run mine a little underinflated which makes quite a difference at low speed, the figures given are assuming a full load. The BMW gives different pressures for fully and partly loaded and they are quite a bit different.
There is quite a variation in tread stiffness between different tyres, what I have done in the past is to get my local friendly tyre fitter to let me 'feel' the tyres on offer, hold them by the edge and press your thumbs into the center of the tread and see how much force is required to push it in.
Anyone else care to take up "Tyre Feeling" :-D
Well done on the 10,000 Peter!
x 8048
If you go and buy 9999 2.4m fence panels you could erect a 23.997km fence with your 10,000 Posts Peter!! Congratulations and well done that man!!
Manufactured!!
Manufactured!!
x 8275
mickthemaverick wrote: 18 Sep 2020, 16:14 Image
Love it :) And huge congratulations Peter!!!
x 1240
Unread post by Peter.N. »
Thanks all. Was it really that long ago. :? :(
x 3566
Double-entendres on a postcard please, to:
Frankie Howerd,
c/o the usual address........ :-D
Didlecock signpost - own work
And a nearby bridge complete with old reference number:
Cocking bridge - own work
x 8275
Loving the fingerpost sign :) I'm a fan of them and a few years back took many photos of them both around here and in Somerset :D
What railway once ran across that bridge? I'm always interested in disused railways and the remains of them still extant...
x 3566
That was the old Chichester to Midhurst line. I can still remember the Chichester end up to Lavant being worked as it served the sand and gravel pits - I think some Youtube video exists of one of the last workings under diesel. Midhurst was served from 3 directions back in the day - from Pulborough, from Petersfield, and from Chichester. The track bed from Chichester up to Singleton has been converted to The Centurion Way cycle track, with plans to finish the job up to Midhurst..... though whether that happens in my lifetime is another matter :roll:
x 8275
bobins wrote: 19 Sep 2020, 18:41 That was the old Chichester to Midhurst line.
Brilliant :D Thanks Bobins! I shall now go and do some deep research into that line :wink:
x 7163
On a little delve this sign popped up, in the same sort of area I think.
https://scontent-lht6-1.xx.fbcdn.net/v/ ... e=5F8BCA51
