I was happily driving the Civic on the 5 gears when my son pointed out that it has six
- x 5674
Re: Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
Is it the one marker "R" - for rallying?
Skull
- (Donor 2026)
- x 380
Glad to hear the adventure went well Jim
That's about the only negative of those 2 litre AX's ..they've only got room for a 4 speed box
I still pine for another AX, my favourite so far was my 1.4D 3 door Echo, super cheap motoring for 5 years which had the desirable 5 speed box
four speeds are fine for around town but just a little buzzy @ 65 mph + on motorways.
Gary
Gary
- x 7164
I presume that's the rising sun on your early morning run picture Jim doing a reasonable impression of a sodium street light
I get the impression you enjoyed your trip
and also strangely enjoyed the little bit of car fettling too
I did notice that Daffodil has one of those things I try to avoid....a winter MOT. Alright winters recently aren't what they used to be, but even for the most enthusiastic car-fettler, fettling a car at the end of January is more likely to be a PITA than not. I imagine for you it would be a take-it-in-your-stride thing, but me I would be putting it in for an early one pronto.
- x 1240
Well done on your adventure Jim, I'm sure it,s done you the power of good.
- x 8391
Skull wrote: 13 Sep 2020, 09:01 That's about the only negative of those 2 litre AX's ..they've only got room for a 4 speed box![]()
No, that's a sodium street light NeilNewcastleFalcon wrote: 13 Sep 2020, 09:27 I presume that's the rising sun on your early morning run picture Jim doing a reasonable impression of a sodium street light![]()
Here's another view of it from the opposite direction showing the light on a telegraph pole... Both photos taken around 6:30 AM..
I certainly did enjoy a bit of fettling
I agree about the Winter MoT... I may see about moving that to the spring... I did the same with Sally as she originally had a winter MoT too.
I've just ran a 5K race around the Daytona kart racing track in MK... I ran my fastest 5K in a long, long time... I think it was 2018 I last managed a low 8 mins/mile pace
As I started my race 'The Chain' by Fleetwood Mac started playing in my headphones from my Garmin music running playlist! Somehow it seemed very appropriate... I have my playlist on a random shuffle... What were the chances?
On cloud 9
- x 5674
Wit regard to the sodium lights, I mentioned that I would look when the ones in the street lit up to see the colour progression.
Unfortunately they have turned them all off, presumably from a central location as none are working now - there were al least three working last week. They did start of very red and got progressively brighter and more yellow over about three~five minutes.
- x 7164
CitroJim wrote: 13 Sep 2020, 10:23 No, that's a sodium street light NeilI'm busy collecting them photographically now before they go extinct
Apologies everyone, but if you are tired of watching paint dry try this. It does appear that low pressure sodium street lamps could well be extinct "on the street" now, but I guess this "slower" and more red at the start sequence was what I remember from the street lamps of my youth
- Spoiler: show
The follow on video to that on High Pressure Sodium Lamps may result in a different colour sequence depending on the gas used eg Xenon/and whether mercury/sodium is part of the mix. Mercury has a blue light/Sodium Yellow so the HPS could be less yellow on full warm up, and Blue will appear in the warm up sequence.
I'm sure you know much more about it than me Jim but I take away that not all sodium lamps are the same! Am I right in thinking that any sodium lights still on the streets of the UK will be HPS of one form or another, and may not, unless they have Neon Gas in their composition glow red on start up like the old LPS lamps did.
Michel
My condolences on the loss of your friend Jim, however I feel a traditional funeral and burial/cremation would be more appropriateCitroJim wrote: 13 Sep 2020, 06:44
The only sad bit was the news I lost an old friend to the Big C on Friday
Now to start clearing the garage so she can live inside![]()
- x 8391
Michel wrote: 13 Sep 2020, 11:53My condolences on the loss of your friend Jim, however I feel a traditional funeral and burial/cremation would be more appropriateCitroJim wrote: 13 Sep 2020, 06:44
- x 8391
All the ones I'm recording for posterity are, I believe, the few remaining low pressure sodium (LPS) ones still extant in the wild NeilNewcastleFalcon wrote: 13 Sep 2020, 11:22 It does appear that low pressure sodium street lamps could well be extinct "on the street" now
That's a great find NeilNewcastleFalcon wrote: 13 Sep 2020, 11:22 This is a much better explanation, or it sounds like that to me (even though its recorded in "American"![]()
I'm still learning NeilNewcastleFalcon wrote: 13 Sep 2020, 11:22 I'm sure you know much more about it than me Jim but I take away that not all sodium lamps are the same! Am I right in thinking that any sodium lights still on the streets of the UK will be HPS of one form or another, and may not, unless they have Neon Gas in their composition glow red on start up like the old LPS lamps did.![]()
- x 1240
You can come and photograph mine Jim if you like.
- x 8391
Next time I'm down your way I will Peter
- x 3306
I wonder if BBCs' "Top Gear" pinched your fifth gear so Channel 5 can no longer compete?
- x 8391
Hell Razor5543 wrote: 13 Sep 2020, 18:50 I wonder if BBCs' "Top Gear" pinched your fifth gear so Channel 5 can no longer compete?![]()
The operation to make room in the garage to accommodate Daffodil is soon to commence... Skip to be hired
Chris570
- x 36
Surely a skip isn't needed! There can't be much left in there? Pleased you're back in an ax, I do miss mine.
Stupid question but being a 3dr do you know if you can open the door with the car in the garage?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
