RT4 upgrade path
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
osx
(Donor 2022)
x 15
RT4 upgrade path
Unread post by osx »
What upgrade options are available without extensive modifications (with or without replacing the screen)
C5 X7 Exclusive 2.0 HDi Auto
x 6950
Re: RT4 upgrade path
On a C5 X7?
Within PSA systems: MyWay (RNEG), RT6 (RNEG2), Navidrive 3D (NG4).
But I would avoid MyWay. NG4 is a Double DIN system and they cost a bomb, so RT6 or another RT4 which is a perfectly good system, just without Bluetooth.
You haven't said what the problem was with the RT4. Nothing a CF card upgrade won't fix if it is the Hard Drive that is shot.
osx
(Donor 2022)
x 15
Damaged CD cable so not able to use the RT4 DVD to upgrade the system. USB is enabled and working with flash drives but getting CRC errors. Doesn't seem to have enough power for my portable CD player.
osx
(Donor 2022)
x 15
Trying with a powered external dvd player but not progressing past the "Insert upgrade cd" screen
x 6950
FAT32 is preferred for USB drive in case it's not and is the source update an original CD or a copy?
osx
(Donor 2022)
x 15
I'll try with FAT32 instead of the default FAT. The source is the original CD.
osx
(Donor 2022)
x 15
No change with fat32 either. Will try with a new cable in the weekend.
osx
(Donor 2022)
x 15
What are the negatives of the MyWay as I have found a cheap one - is the screen the same with the RT4?
x 6950
The MyWay uses the low resolution screen and the RT4 should be ok as it can support low and high res.
In case it is important to you, be aware that despite what it says in various older owner handbooks, the MyWay system does NOT play media files from the SD card and does not support bluetooth media streaming!
It can only play media files such as MP3s from an MP3 mastered CD or a standard CD. It can play MP3 / WMA media files from the AUX input if fitted - but provides a rudimentary function only.
osx
(Donor 2022)
x 15
Got it to work at the end. Interestingly I didn't have to set the SSD as slave or master.
