C5 rear suspension fault
x 6956
Re: C5 rear suspension fault
fastjet wrote: 30 Aug 2020, 18:18 Hi Marc, thanks for the height measuring information.
Should H1C = H1M as it says compare them?
Thanks you for the advice.
H1M should be equal to H1C or within plus or minus 2mm of it.
x 3304
fastjet
x 8
Unread post by fastjet »
Hi Hell Razor5543.
Yes it certainly does, mine looks like that so I've just got the ride height to check.
fastjet
x 8
Hi Marc. I have adjusted the ride height following the instructions you kindly provided. Could you now explain what I need to do with lexia please?
