parts for C5 X7 2.0 gasoline
rrijken
Unread post by rrijken »
Looking for following part numbers for my car:
1. fuel pump (if any gaskets need changing then these as well)
2. O2 sensors
3. Injectors
Help appreciated!
Robert
x 1746
Re: parts for C5 X7 2.0 gasoline
A VIN number will help with this.
x 6948
I've got it already Chris :wink: .
Robert: If there are any other parts on the diagram you need, let us know.
Injector (2) with washers: Part 1984F8
Injector Clamps (4): 198257
O2 Sensors:
Upstream (1): 1618Z6 (long 555)
Downstream (2): 1618AL Long 1250 7W)
The actual fuel pump is incorporated with the fuel gauge in the tank:
Fuel Pump / Gauge (2)
Part: 9687218480
rrijken
Marc, thanks! Parts for the fuel pump, number 5 and 6 also need replacing guess? If yes, part numbers for these would be appreciated as well.
x 6948
You shouldn't need (5) which is just the hard plastic securing ring - your original will be fine, but the seal (6) is part: 153141
rrijken
Thanks!
