dearmouring berlingo pump
wedge55
Does anyone know when you are dearmouring a delphi injection pump on a 2007 berlingo on the armour there is a roll pin that holds armour onto thick metal plate running through armour and i hve a feeling fits into a groove on fuel union into the pump , how this is removed backwards or some other way.before i have a go i thought id ask here thanks
KennyW
- x 165
Re: dearmouring berlingo pump
If it's anything like the pin on the Xantia bosch pump, there are a PITA to remove. I had to drill mine out carefully.
It supposed to be 'pulled' out but the fit is tight and difficult to grip.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
