Driver Comfort on 2013 C5 Tourer
- x 1938
Re: Driver Comfort on 2013 C5 Tourer
I had never thought of using the position of the mirrors as an indicator of whether the car is locked or not but I also would choose the Mk1 system if it were available as a choice.
Jobeau
Marc, Thanks for your reply. Tried it with the following result.GiveMeABreak wrote: 19 May 2020, 22:59 Hi John, I have moved your post here.
The feature you are referring to is called the 'Welcome' function.
It can easily be disabled if you follow the manual. It cannot be done whilst the car is moving for safety reasons. To turn the feature on or off, press the left hand scrolling wheel button on the steering wheel.
From the menu, and scrolling the wheel, select 'Vehicle Parameters', then select 'Comfort'. From there you should see the option to activate or deactivate the driver's welcome function.
Left hand scroll wheel / Vehicle Parameters / Driver assistance but only item to tick or untick is Rear Wiper in Reverse Gear.
Still looking for a solution. John B.
Jobeau
Checked again for COMFORT but under Vehicle parameters I only have Choice of Units, Language and Driver Assistance.
- x 6945
Hmm.... and what do you have under driver assistance?
