Relay 2002
Fra21r+
My Cars: Citroen relay 2.2
Re: Relay 2002
Post by Fra21r+ »
Hi John
the price of the correct stalk) - will make future sojourns down the autoroutes a bit nicer!
Be interested in that
Do you have a link to the stalk
jgra1
(Donor 2021)
My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong
x 39
Re: Relay 2002
Post by jgra1 »
its an Alfa Romeo stalk ;) - (Fiat parent company?)
link https://www.fiatforum.com/ducato/475643 ... ctory.html
you will need the 4 way brake switch, this switch needs a few mm cutting off the end. Its a bit of a pig to remove and replace but I managed! also need some wires to reach from the LH dash area to the column
here's a typical stalk https://www.ebay.co.uk/itm/Alfa-Romeo-1 ... Sw1b5fCLsv
Fra21r+
Re: Relay 2002
Post by Fra21r+ »
Good news
Cluster sorted it
Also had effected the fuel gauge
Down point.. went from 136k to 300k 😂😂
Thanks for the input folks
Fra21r+
Re: Relay 2002
Post by Fra21r+ »
Hi John
Do you use the whole switch gear from the alfa (wipers and light slalks
My Cars:
x 732
Re: Relay 2002
Post by wheeler »
Fra21r+ wrote: 29 Aug 2020, 19:04 Good news
Cluster sorted it
That was definitely a strange one. If you left the ignition on for a few hours you could have ended up with much more than 300k 😆
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Re: Relay 2002
Post by jgra1 »
re cruise : no, remove the CC from the alfa stalks and use it alone. there is a mounting hole in it, when you add to your existing column, just don't use a screw that's too long otherwise it will go through your existing indicator track :twisted:
you will need to carefully cut the column shroud; route the wiring over column and behind dash somewhere; find that black plug near passenger fusebox; etc etc
Post Reply
