2007 berlingo 1.6hdi engine swap
Clarky021
Unread post by Clarky021 »
Looking to source a replacement engine for a 2007 berlingo 1.6hdi and need some advice please.
Will a Peugeot 208 engine code dv6 go straight in or will it need modifying.Got the chance of a pug 208 engine on a 2008 car with all ancilleries fitted and wondered if it will go in and what would need swapping over?
Not a got a lot of experience doing this after only swapping engines on old classic minis which is somewhat easier.
Will the ecu off the old engine need swapping over as well?
Any advice appreciated.
x 3296
Re: 2007 berlingo 1.6hdi engine swap
Hi, and :welc: to the forum.
What you will need to do first is to post up the VIN here (it will, for security reasons, be obscured so only Forum staff can read it). That way they can work out the exact spec of your Berlingo when she rolled out of the factory. Because the PSA Group now charges for that information you may have to pay a donation (I believe £10 will cover you for up to two years of searches). Then forum staff can tell you what type of engine could be fitted, and what else would need to come across from the donor vehicle.
