C5 ll Dash fascia
All the sticky threads from the Citroen and Activa forums have been relocated here at least on a temporary basis.
Ceenine
x 17
C5 ll Dash fascia
Unread post by Ceenine »
I need to change a headlight telltale light (it is blinking on different occasions) in the dashboard. Is there an instruction about here I can locate to tell me how to extract said light.
I thought it may have been telling me that the light may have been stuffed but that is not the case.
Don
x 6945
Re: C5 ll Dash fascia
Which light Don? "headlight telltale light" is Japanese to me :-D
If this is your C5 II, you'll have Xenon D1S bulbs and also and H1 Main beam for the headlamps, then there are the small W2W side lights that run up the outer edges of the headlamps.
x 5673
The one in the instrument binnacle Marc
x 6945
What the green dipped or blue main beam 'lit' bulb in the instrument cluster?
furriegurrie
x 40
Unread post by furriegurrie »
If that is blinking it’s indicating a fault in the operation of (1 of) the headlights. Either 1 did not ignite when switching on or there is an issue with the auto levelling. Either way, that dash light is working as intended.
