My ZX Estate
Huskyxantia
x 918
Re: My ZX Estate
Unread post by Huskyxantia »
ImageFound something strange behind the front bumper .
No not the neighbors cat ..
It plugs into the loom and is like a long plunger thing
:-D
x 1746
Re: My ZX Estate
Image won't open...
Plugs into the loom? Could it be a shuttle, part of a warp drive system? :-$
Huskyxantia
x 918
Re: My ZX Estate
:rofl2: To infinity and beyond.
I'm having trouble uploading my photos ,it my mobile being a pain .
:-D
Huskyxantia
x 918
Re: My ZX Estate
Its called a Dim-dip system
Resistor and there's a relay in line as well, my one is smashed and rotten ...
Wonder where they can be purchased
The dim dip relay is supplied with current from the side light circuit and energised from the ignition being switched on, it allows battery voltage to pass through the resistor to the headlight dipped beam circuits.
It lights the head lights one sixth of there normal power so the car can't be driven using side lights Alone.
OK, so that's why my side lights work on there own because my part is broken and rotten !!
This was law a while back ... How things change
:-D
x 5672
Re: My ZX Estate
You can legally bypass it now.
Huskyxantia
x 918
Re: My ZX Estate
myglaren wrote: 04 Jul 2020, 17:54 You can legally bypass it now.
My side lights work
Headlamps and main beam.
Its not plugged in as I pulled it out the socket .
How do you bypass it
:-D
Huskyxantia
x 918
Re: My ZX Estate
I did read Vauxhall bridged the plug wires as they were catching fire , that was a while back.
:-D
x 1746
Re: My ZX Estate
Dim-dip is a bit historic nowadays, but made sense, particularly in daylight-limited territories. A predecessor to daylight running lights.
Running high-wattage devices through a resistance (eg cooling fans, blowers, headlights) isn't very clever, as the dropper resistor needs to dissipate lots of power (heat).
Much better IMO is to run two devices in series-parallel. This is now standard practice for twin cooling fans, and can also be done for dip-beam headlights. All that's needed is 3 relays, and there is no wasted heat generation,
Huskyxantia
x 918
Re: My ZX Estate
Checked the lights last night after putting front wings back on , all working I'll have to tape up the socket which the resistor used to be plugged into just to keep water out.
:-D
Huskyxantia
x 918
Re: My ZX Estate
Any body following this chap he's doing a pretty good job
:-D
Huskyxantia
x 918
Re: My ZX Estate
My ole girl still going strong
:-D
