Trying to find oil leakage XUD9
CPtje
Re: Trying to find oil leakage XUD9
Unread post by CPtje »
Nice, so it is okay to just remove one cylinder head bolt only. Will need to get the right socket wrench first and look up the right figure to fasten it again. Do I need to replace the bolt or can I re-use this one?
Replacing the HG is probably too difficult for me, so let's see if this will help.
x 1746
It's unusual to remove just one cylinder head bolt, but I don't think it will do any harm in this unusual circumstance.
Might be worth checking that it was actually properly tightened, when you get the socket and the torque figure.
If that O-ring in the corner of the HG goes leaky, engine oil under pressure (up to 6 bar) can find its way in various directions. It can leak across the HG and into a nearby waterway (you then get engine oil injected into the coolant), or into the neighbouring cylinder (unusual, because the HG is reinforced around the cylinder bore - causing the engine to burn oil), or leaking across the HG into the ouside world (oil dribbling from the HG and down the side of the engine).
What you seem to have (oil around the head bolt) does seem to be consistent with the O-ring going leaky. Just my best guess.
x 5672
white exec wrote: 09 Jun 2020, 13:15 What you seem to have (oil around the head bolt) does seem to be consistent with the O-ring going leaky. Just my best guess.
Is this not a common problem with the XUD or was that another PSA engine?
x 1746
It was a common problem with XUD. On BX diesel, a poor header tank arrangement (just a large air gap at the top of the radiator on some models) could lead to air locks and hot-spots in the head, which warped the head and allowed the HG to leak. The oilway captive O-ring (part of the HG) could also bake hard and go leaky. Same thing not unknown on XM 2.5, if cooling system is neglected.
CPtje
Okay, all visible oil leakage but one are resolved. Did cost me some effort to get the cam cover leak free, but finally succeeded with all your help.
However, the real problem is not solved. 1ltr of oil is disappearing each 400km. So now, the real question is... is it the engine or the turbo. Is there a simple way to know this for sure. The turbo looks "wet" from the outside.
I cannot say that I have lots of blue smoke, but I can smell burned engine oil sometimes when driving with the windows open.
For instance, is there a way to check if the engine is burning oil by taking of the turbo somehow? Is it possible, would it work to check this way if the engine itself is okay?
Pricewise, a new turbo would be okay if I am sure the engine isn't the problem. However, if the engine would need a complete overhaul, I might be better off with a replacement engine.
CPtje
Extra info: Just took of this piece of hose from between the turbo and the intercooler. I can't remember it to be this wet some years ago. Is this more than just from the fumes? Can this be only because of the turbo or can there be another cause for this? ( and the oil usage of 1ltr on 400km).
x 1746
Not unusual for the pipework from turbo to intercooler to be oily, and inside the intercooler too.
With the car parked up and engine properly warmed up, if you boot the accelerator hard, is there any sign of blue smoke from the exhaust? Black smoke would just be down to the extra fuel being injected; white smoke could be glycol coolant getting into one of the cylinders, and burning (unlikely - you would have mentioned that).
As you say, 1 litre in 400km is either a physical leak, or it's getting combusted.
How's the compression? Just wondering about piston ring condition?
Another possible route for heavy oil consumption is worn valve-guide O-rings, which let oil from the valve/cam area get sucked into the cylinders.
moizeau
x 423
Unread post by moizeau »
Have a friend follow you at night. Headlights show wonderful things. If valve guide seals are that worn I'd expect very sooty heater plugs and a puff on gear changes. Have you looked at the heater plugs, not from a starting issue from a 'spark plug' point of view, are they a nice light grey?
My BX's oil used to get up to the air filter but didn't use much.
Sounds like it's starting to drink it's own oil if there are no obvious leaks externally.
Pete
CPtje
No white smoke. No oil in coolant.
Some grey/blueish smoke but not that noticeable.
Compression not checked. Need to have this done in a garage.
Anything more I can check for myself? More ideas?
moizeau
x 423
Whip the glow plugs out and see if any are sooty.
Pete
CPtje
Took the glow plugs out this morning. They are 3-4 years old. It always starts without a problem. They are not really wet or something. But the left one does not look right. It's from the most right cylinder. Is this sooth or something else?
Or would you define this as all 4 are soothy because they are not white grey at the tip?
x 5672
Might be a good thing to test them while they are out.
If they are faulty then Beru replacements are recommended.
CPtje
To check if the turbo compressor is leaking oil someone advised me to run the engine warm, remove a piece of hose from in-between the turbo and the intercooler and then place a piece of paper in front of the pipe and run the engine for 30 seconds on 3000 to 3500rpm.
I did so and here is the result...
Placing a piece of paper.
After engine running for 30 second.
I assume that this oil can only be from leaking bearings in the compressor or might there be another cause for this.
Please give me your thoughts on this.
x 1746
That does point to the turbo blowing out oil.
Might just be worth fitting a new/reconditioned one.
Barney00731102012
Unread post by Barney00731102012 »
Ah ha someone else who seems to be having the same problem as me, and it’s doing my head in, I’ve put three rocker cover gaskets on it since the engine was fully rebuilt. Now it’s leaking oil again I can’t for the life me see if it’s 100% the rocker cover gasket again so I’m going to remove the engine undertray tomorrow and get a better look. Great way to spend my holiday.
