hi does anyone know what bulbs the dash and aircon are for my 2003 xpic 2.0
i bought 20- t10 501 bulbs in purple but they are far too big for sockets
many thanks in advance
what bulb ???
- x 6962
Re: what bulb ???
Yes, you need T5 1.2W or 286 bulbs.
They are usually wedged into the small plastic holders that you twist out to change.
p1cass0p0w3r
Re: what bulb ???
cheers dude...few other minor jobs and my xpics done (2nd xpic they such a comfortable drive.)
- x 6962
Re: what bulb ???
My relative is selling her 2009 Exclusive diesel with the full electric panoramic roof - they loved it, but have now got a new C5 Aircross. I've just replaced a load of dashboard and climate control panel bulbs - so that's how I know
p1cass0p0w3r
Re: what bulb ???
mines an 03 exclusive diesel with elec panoramic roof i (-expletive removed-) love it (but not sunburned scalp ha.)
mine also has a cruise control stalk which isnt working or i dont know how to use it
but im deffo going to keep this car an try to sort last few niggles......even when i do scrap it i will deffo find another one the same
- x 6962
Re: what bulb ???
Cruise control:
1) On the stalk, make sure the wheel in the middle (1) is scrolled up to 'ON'
2) Cruise will only work in 4th gear or higher and at speeds of about 25-30 MPH or higher, but I would say a min of 30 MPH from experience.
3) Get to the speed in 4th or 5th you want then press on button '2' or '4' to set the speed.
4) The speed can be increased using '4' or decreased by pressing '2'.
5) Once you press the clutch or the brake pedal it will be deactivated automatically.
6) it can be resumed or paused by pressing the end button (once you are in the right gear and min speed of course).
Be aware that if there are any engine fault codes showing, some of these will cause the engine management to disable the cruise function until the underlying problem is fixed.
