3008 1.6 hdi automatic Juddering
LionMan1980
Unread post by LionMan1980 »
Hi all, I have a 30081.6 hdi 2010 automatic, would like to ask if anyone have trouble in low temperature a feel like gear slipping or judder usually in the morning when you start driving !! But once the car is warm, it doesn't do this, please help with advice !!
Told the dealer few times, but they said without any error codes nothing much to do !!
thanks
x 1459
Re: 3008 1.6 hdi automatic Juddering
Unread post by xantia_v6 »
I would suggest that the transmission fluid level should be checked. The fluid expands when warm, so if the level is low, the symptoms are first seen with a cold transmission.
LionMan1980
Many thanks mate, just suggested this to my mechanic today, while the car is in for timing belt change (10 th year and 123612 kms), hopefully this can solve the issue !!
LionMan1980
Asked the mechanic to check but he did a general check up, no change in juddering, how can I check this fluid on my own ? thx
