08 reg dispatch, front drivers door light warning flashes on right turns
Slyp98
Unread post by Slyp98 »
Hi guys n gals strange one this, been having the warning leds flash FR DOOR OPEN on cornering, always right turn , I cant even find the drivers door switch, thanks
x 1056
Re: 08 reg dispatch, front drivers door light warning flashes on right turns
Unread post by wheeler »
The door open switch is an integral part of the door latch assembly.
Slyp98
I see thanks
x 3303
I would check that the lock, hasp bolts and hinges are tight. If they are slightly loose that could cause the effect you are having (as something must be moving enough to cause the switch to change status).
Slyp98
Cheers will check everything this weekend
