Faulty wiring
Shaprog2010
Faulty wiring
Unread post by Shaprog2010 »
Hi, I have a Citroen relay 2011 and ever since I bought it I've had a problem where sometimes it will crank over but won't start but if I wriggled the wiring under the fuse box in the engine bay it would start, obviously the dreaded French wiring I've read about. Now the van won't start at all :( , I've checked the wiring but can't find anything, can anyone give me any advice please.
x 1056
Re: Faulty wiring
Unread post by wheeler »
Shaprog2010 wrote: 29 May 2020, 11:29 obviously the dreaded French wiring I've read about.
The Relay is just a re badged Fiat Ducato so it's actually dreaded Italian wiring :wink:
Do all the dash lights come on as normal? You will probably need a diagnostic session to start with.
Shaprog2010
Re: Faulty wiring
Thanks for your reply. Dash lights up as it should, no fault codes showing.
