The heater on my C5 is stuck on the 2 top speeds no matter how i adjust the temperature settings in auto mode or the fan speed in manual mode.
Having read a couple of threads on this forum (thank you!) I have found and removed the heater resistor. The part number on my resistor is Behr F8840002. I was hoping someone could check my Vin number and confirm if this is the correct part? The main reason for asking is it was different from the part number on the other thread (6441S7) and when I'm searching for a new one my part is a lot harder to find and only showing listed for other cars, not the C5.
My Vin is VF7**************[VIN obfuscated, can be read by forum staff]
Citroen C5 X7 Mk3 heater resistor part number
- x 1056
Re: Citroen C5 X7 Mk3 heater resistor part number
Behr F8840002 Is the component manufacturers part number which will be different to the Citroen part number, Looking at this yours may still be 6441S7. Does it look the same? connector the same?
EuanT
Yes it looks exactly the same as 6441S7
- x 6954
You need 6441S7 for your X7.
EuanT
Thank you both.
Much appreciated
Much appreciated
