Faulty codes Citroen c5 hdi 2011 163 hp - need help!
Der_Bomber1978
Unread post by Der_Bomber1978 »
Hello!
Have never posted before, but have gained so much help here in the past from reading others.
I have a 2011 Citroën C5 hdi 163hp.
180000km, have been running great up until lately. I have orange engine fault in my dash.
Checked out the faulty codes and gets the following:
P107a
P1497
P2562
It said something about low turbo pressure and I get the feeling the car is a bit slower in acceleration. Can this be the EGR?
Or what does you guys here say? Anyone that know this problem.
Cheers, Filip
x 5672
Re: Faulty codes Citroen c5 hdi 2011 163 hp - need help!
Please don't duplicate threads - we have removed the other one now.
Reason: Edited to reflect changes
x 6945
I deleted that thread Steve and left the one here once I saw it :wink:
x 6945
Der_Bomber1978 wrote: 18 May 2020, 05:50 Hello!
P107a
P1497
P2562
Cheers, Filip
Hi Filip
P107a: Boost pressure regulation: Air pressure below the reference value (APV).
For an engine speed between 2500 and 3750 rpm and an engine torque less than 275 Nm: The fault appears if the turbo air pressure measured is lower by 800 mbars than the reference for 6 seconds.
For an engine speed between 2000 and 3750 rpm and an engine torque less than 320 Nm: The fault appears if the turbo air pressure measured is lower by 450 mbars than the reference for 6 seconds.
The fault is active when the engine speed is above 1500 rpm / the engine torque is greater than 100 Nm. There can be lots of reasons for this including:
  • Atmospheric pressure sensor: Sensor fault, Clogged air filter, Flowmeter: Failure of the air temperature sensor
  • Air line between turbocharger and mixers: Air leak
  • Air line between mixer and engine (including EGR valve take-off): Air leak
  • Turbocharger air cooler: Blockage; Loss of charge
  • Turbo pressure sensor: Sensor fault; Electrical harness
  • Turbocharger: Seizing of the variable geometry; Wheels broken in the compressor or turbine; Turbocharger shaft broken; Air leak / Gas
  • Turbocharger solenoid valve: Failure of the solenoid valve; Electrical harness
  • Position indicator of the turbocharger: Sensor fault; Electrical harness
  • Exhaust gas recycling valve: Seizing; Internal leak
  • Exhaust gas recycling electric valve position copy signal: Sensor fault; Electrical harness
  • Oil: Damage to the oil (carbon, dilution, oxidation); Poor lubrication; Thick oil
  • Cracks in the oil sump; Under bonnet or underbody oil leak
  • Filter broken; Lack of lubrication; Poor lubrication
  • Oil pump broken; Lack of lubrication
  • Lubrication circuit of the turbocharger: Oil leak; Poor lubrication
  • Vacuum pump: Broken
  • Vacuum circuit: Hose leak; electrovalves
P1497: Variable geometry turbocharger: Position incorrect in relation to the requirement - Not enough turbocharging. The position measured is greater than the reference by more than 30 % for 6 seconds.
Possible Causes:
  • Turbocharger: Variable geometry open
  • Position indicator of the turbocharger: Electrical harness
  • Vacuum circuit leak
P2562: Variable geometry turbocharger: Position incorrect in relation to the requirement; Not enough turbocharging. The position measured is greater than the reference by more than 40 % for 6 seconds.
When this fault is present the EGR function is deactivated.
Possible causes:
  • Electrical harness
  • Vacuum circuit
Der_Bomber1978
Cheers Marc! Ok seems like i have some stuff to look at. Turbocharger looks like a possible red thread.......
Filip
Der_Bomber1978
Does anyone know what turbo to buy? What brands works best, fit well och is easy to fit?
Henkel, BTS, Alanko, Lucas, Garrett are just a few i have seen online.
Your inout would be very nice. Cheers!
Filip
x 1461
Unread post by xantia_v6 »
How have you determined that your current turbocharger is faulty? Have you tried spinning it through the inlet port?
There is also a good chance that the real problem is with the vacuum system that controls the waste gate.
Der_Bomber1978
New to this problem. I will def yry to check that before moving on with any new turbo. Any goid videos on youtube on this type of problem i have? Spinning inlet port and how to determin function of vacuum system/wadte gate!
Thankful for all you advice and input👍👍👍
