My apologies if this question is posted in the wrong place.
I am trying to install a bog standard radio/cd using Lexia. Should I be using the vin. no. of the vehicle that the unit came from- or the vin. of the car I am fitting the unit into?
I'm missing a trick somewhere- the bleeping stops all the time I am connected to Lexia, but as I close the program back down it starts bleeping again.
Xsara Picasso radio programming.
discv
- x 24
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
moizeau
- x 429
Re: Xsara Picasso radio programming.
Your Vin
Pete
discv
- x 24
The vin of the car I want to install the radio is- VF7**************[VIN obfuscated, can be read by forum staff]
The vin of the car that the radio has come from is- VF7**************[VIN obfuscated, can be read by forum staff]
moizeau
- x 429
Sorry, meant to read, you code the radio to the car it's now in
Pete
discv
- x 24
Please make this simple for me
- x 1056
You must change the VIN stored in the radio to match the car it is fitted into.
discv
- x 24
And I thought this would be a doddle! At no point do I see any sign of the vin. that the radio came from to be able to edit it.
I'll have another shot tomorrow. Thanks guys.
- x 1056
Select radio from the global test screen then select programming. If I remember right the VIN is the first line. Just delete the old VIN & type in the new one. There is a button to press on the screen to save the VIN.
discv
- x 24
Missing a trick? I entered the wrong RPO
All is now well!
