C5 X7 Nav dash panel
This section is for General Enquiries or for Systems not Covered Above
elcustardo
x 9
Re: C5 X7 Nav dash panel
Unread post by elcustardo »
Okay. So finally got round to finishing this (well sort of)
I used an acrylic Rasberry PI 7" touchscreen mount as a base for my screen mount. Worked really well
Used the 2 complete rectangles to sandwich the screen and chopped up what was left and built ears onto the frame to fit where the OEM screen bolts in. Planned to drill and bolt it in but in the end I got such a neat fit it wasnt required.
If I find issues with movement I can still drill and mount if needs be.
So Ive found out the features seem pretty much all in the head unit not needing the screen to work.
Found out as I accidentally caught the screens power wire and cut it :oops:
Headunit isnt too bad in design if a bit blocky. lights up orange like the console with the lights. A touch brighter than the rest of the lights if I was being critical but it is just a touch.
Radio does sit fully home but Im still sorting out the rear wiring and where ill run the head unit USB through.
Havent had a chance to test if it integrates with Android Auto over usb or not.
Also the radio reception is fine. It seemed poor until I discovered I had dislodged the aerial lead previously :roll:
Handsfree,bluetooth audio etc works fine.
Apps can be installed with around 10GB free space showing.
Havent tested the DVD drive.
x 1952
Installation looks professional and quite OE. Well done.
elcustardo
x 9
Paul-R wrote: 02 May 2020, 16:56 Installation looks professional and quite OE. Well done.
I'll be honest it wasnt that hard. The PI frame I used was near perfect on its own.
All it required was the 'ears' to slot into the OE mounting points.
I then built up those ears with more acrylic pieces to bring the screen forward.
I originally used some plywood to measure up and make an approximate template for sizing,mounting hole location etc.
I was going to cut it direct from an acrylic sheet and stumbled on the screen mount.
oli_25_uk
Unread post by oli_25_uk »
Looks great - what head unit did you buy?
Also - do you have parking sensors - if so, do they still work? I'm especially interested to know if the front ones work and if the parking space monitoring function still works?
Oli
