I have a drivers seat that needs replacing, I have been offered a replacement drivers seat but it has heated seat function and is powered.
Question is my current car has neither. Will the replacement seat simply plug and play?
Replacement seats
- x 6956
Re: Replacement seats
You won't have the relative control module, electronics or wiring harness fitted and of course you can fit the seat only, but it won't be adjustable.
The seat harnesses alone number in excess of 20 versions, depending on model, fitted options, lighting packs, seat version, seat electronics. AFIL, heated options etc.,
derbyshire1970
Thankyou. Worth asking before buying. Does any body know where I can get seat repaired split leather and foam support has crumbled away. It is only seat base and not the upright
- x 3304
It could be worth checking if the bases are the same between the driver and the passenger seat. If they are (once the lockdown is over) I would suggest you call into your local scrap yard and see if you can get one that way.
Steveo
- x 13
Hi
A1 Trimmers near Knottingley
Check out website
Regards
Steve
Check out website
Regards
Steve
