Yes, I've still got the ****** thing. My 5th Citroen purchase turned out to be a dog from day one. The legal case against the previous owner for selling a car without declaring a fault (didn't show up on test drive and the computer memory had been erased) has stymied because of the lockdown. It needs a new battery and I have had one delivered, but I'm a bit apprehensive about fixing it - from what I've seen on Youtube it's a bit of a b***er to get out and in. There are two or three issues I'm not sure about: can I 'just' take out the old battery and refit the new one without doing anything else? Is the fusebox sitting on the battery a problem?
Apart from the removal/refitting, what is the whistling noise you get when opening the driver's door? The car has always done this and I seem to recall my (much missed) C5 doing this noise as well.
Finally, I am suspicious about the (old) battery going down; maybe there is a short, or something is taking power when it shouldn't. I intend having a current meter handy as I am putting on the new battery and checking, before I connect up the +ve connector, whether there is any current flowing. If everything is correct with the car, should this current be zero?
I hope I am being sensible.
C4 Picasso 2011 1.6e-Hdi
- My Cars: 2019 C5 Aircross 2litre diesel, auto.
2018 C4 Pic2 Spacetourer auto. Seems nice so far.
2019 C4 Cactus manual. Didn't like it, lots of niggling points. sold.
2011 C4 Picasso excl. - shaping up to be a disaster, bought June 2019. P/X'd
2009 Citroen C5 X7 exclusive, auto, LHD, 207500km (129000miles) now sold
Citroen Xsara Picasso excl. 2004 2.0 Hdi, RHD, 64000miles. (sold)
Citroen C3 Picasso excl. 2016. sold.
Two Xantias, one petrol, one diesel. sold.
In the past: Renault 16 (in about 1977, for a year). With front pass. seat out transported full bathroom suite from Cambridge to Derby!)
Renault 4TL (in 2011, for a year) - x 9
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: C4 Picasso 2011 1.6e-Hdi
Just make sure you follow the BSI Reset / Battery Disconnect / Reconnect Procedure as there are such a lot of electronics on these you don't want anymore issues. Make sure you follow the timings. There are specifics marked in the procedure for Stop Start, Keyless Entry and for those with Electrically opening and closing Tailgate that can be ignored where appropriate.
Thanks Marc
Seems a bit daunting to electronic simpletons like me, but clear enough.
Just a rider question: to get to the -ve on this car it is necessary to take off the fuses (or whatever they are) from the top of the battery. Is this a problem?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Here's a video for a Grand Picasso - but should be the same or similar Roger - much easier than explaining:
Thanks so much, Marc. I'll tackle it tomorrow.
Hi again Marc.................. your video was good, very slightly different to my fixing, but only very slightly.
The car is May 2011, so I was very very surprised to see the date on the battery I took out was 06 10 2010 - the original!
Just one thing came out of the job. When I connected the +ve terminal (last thing to do) there was a spark. More than a tiny 'click' but certainly not a 'flash'. Just a small spark. Is this normal?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Wrong order Roger....
When disconnecting, take off Negative first.
When reconnecting attach the negative last.
The way to remember it is:
When disconnecting the battery you are ' - Subtracting' the cables - so Negative cable off first.
When reconnecting you are '+ Adding' the cables, so connect Positive first
Thanks again.
The destructions showed the +ve last - indeed the fitting and position is so awkward and difficult that it is impossible to put -ve terminal on last. Thanks, however, for the nemonic.
