Rear Screen not working
mychips
Unread post by mychips »
Hi All, I have just got a 406 1.816v 1996 Model. I just have a little problem in that the rear window demister/defogger does not work. When the switch is pressed a yellow light comes on and when released goes off. I have replaced the switch but with no difference. I was wondering if there might be a relay etc, if so where would the relay be.
Thanks for the help
fastandfurryous
x 4
Unread post by fastandfurryous »
check first if voltage is appearing at the strip connectors. If not, then it will indeed be the timer relay which has failed (can you hear a click when you press the switch on?) If there is voltage at the connectors, then it may be that someone has put a big scratch in the rear window, and broken all the stripes. Bad luck if they have, cos they're a pain to repair: Silver conductive goop, and a teeny tiny brush, but only once you've found the break!
