Heated Seats stopped working C5 x7
wfdTamar
Re: Heated Seats stopped working C5 x7
The pads were A$3000 odd a pop and took months to arrive, so I reckon they're genuine. I wonder if Citroen have changed them to another pad that is less likely to have problems as it seems a common issue? Maybe getting so warm and being sat on made them break more easily.
2015 C5 Limited Edition (2.2 HDI) 150 kW 450Nm (Racechip S 179kW 528Nm)
jml
- Locked user account
- x 37
If you’re, understandably, worried about them failing completely but, again understandably, don’t want to wind the garage up, why not explain the problem but tell them you’re prepared to live with it provided they give you a written assurance that, should they fail completely within a certain time then they will resolve the problem at their cost ?
TBH I’ve got used to mine not working and it doesn’t really bother me any longer.
Good luck
Good luck
Julian Leyton (RIP) 2023
wfdTamar
One of the conditions of the warranty is that they don't cover repairs beyond the period of the warranty. Also if they can barely be felt in the weather were currently having here (Tasmania still high teens - low 20's) what will they be like in winter when I want them?
It's funny - I have another car that has them and even on the lowest setting they're too hot (BMW 118). Unfortunately I don't like that car.
If I'd had the seats go out of warranty I certainly wouldn't be paying this sort of money to get them fixed. I wouldn't have bought the car had I known they were duff. Heated seats is a feature I definitely want after having a car that had them (a 2001 Saab 95 Aero wagon I stupidly sold).
- x 6962
The only caveat to that is of course I'm not one of those who wears anything thermal, thick shirts and 4 layers of jumperswfdTamar wrote: 03 Apr 2020, 00:42 .... It does help my argument that those of you with heated seats are saying the base heats the same as the back.
I'm sure there are technical heat transference equations that exist for such things! So may be the test is to wear a pair of swimming trunks and a T-shirt to do a comparison on both front seats?
- x 1981
Bit cruel to slow cook a budgie like that !
- x 6962
teuski
- x 11
I just dug out this thread while seeking the diagram (found it on the first page) for an opposite kind of problem.
I've experienced random cases of drained battery during the past few months i've had my X7. No help from a new battery nor any trace of why it might get drained.
Yesterday i found the reason but not yet the main cause. I noticed that my seats heat up even when the car is in economy mode. And those switches are fairly easily turned to max by accident...
It has served as a taxi cab before and i'm suspecting it might be an intentional "fix"
- x 6962
Very likely, as the heated seats are not designed to work at all without the engine running - and economy mode of course is not relevant when the engine is running - so somebody has likely bypassed the BSI command, or bodged the wiring and of course that's why your battery is going flat. One has to wonder what else has been butchered?
Lezacy
Hello, @GiveMeABreak, you have mentioned that you know the correct resistance of the heating wire in the seats. Could you share?
I've 10 pin connector version, so I found the green plug, which is connected to the wires disapearing in the bottom pad, on one seat there is 2ohms on pin 1,4 and in the driver seat there is 16ohms!? (that is wired).
Do you know if the pads from the bottom and backrest are connected as parallel circuits or there are connected in a row?
Pinout for single socket, which deducted (so correct me if I'm wrong) is:
(I numbered pins from left to right in rows, in position of a hatch on the top. But to be sure, notice that for my list, PIN 2 is empty and is in top left corner.)
1. is +12V,
2. empty
3. brown is connected to the thermistor, pin 2 in heating wire socket
4. I don't know - probably to the heating seat switch
5. I don't know - probably to the heating seat switch
6. Pink connected to the heating wire, in the heating wire socket pin 4
7. orange, connected the heating wire, in the heating wire socket pin 1
8. GND
9. yellow, connected to the thermistor, pin number 3 in the heating wire socket
10. I don't know - probably to the heating seat switch
However, I've no idea how they are numbered in reference to the wiring in the schema on the beginning of this thread.
Assumption is:
1. [4] so +12v
2. Empty
3. [B2]
4. -> ?
5. -> ?
6. [B4]
7. [B1] -> [c2]
8. GND M56, 77, 76 = [1]
9. [B3] -> [c1]
10. -> ?
No idea what would be C equivalent in 10 pin plug. I can't find no where the schema for this newer version.
Also what are the expected resistance values. Could any one help?
1. is +12V,
2. empty
8. GND
Assumption is:
1. [4] so +12v
2. Empty
3. [B2]
4. -> ?
5. -> ?
6. [B4]
7. [B1] -> [c2]
9. [B3] -> [c1]
10. -> ?
- x 6962
Here are the resistances for the X7.
I can't understand your wiring numbering in your post.
From the wiring Diagram I put up, tell me the hardware number of the item that is shown underneath and then I can help with the connection designations, for example:
8310: Driver´s Heated Seat
I can then provide you with the connection info for the pins 1-4
| Vehicle | Seat / Backrest | Measuring Point Pin Number | Minimal Value | Maximal Value |
| C5 (X7) | Seat | 1 - 4 | 0,72? | 0,95? |
| C5 (X7) | Seat | 2 - 3 | 4 k? | 10 k? |
| C5 (X7) | Backrest | 1 - 2 | 0,79? | 1,05? |
Lezacy
I've this single plug module, i can't find it's pinout.
Pins I've numbered are done in relation to this plug in the picture below. So 1 is upper left corner, 2nd is empty, 10 is bottom right corner.
When it comes to the schema for one 8310. it has this single plug with 10 pins.
1. [4] so +12v
2. Empty
3. Pin [B2] of 8310 goes to the thermistor of the seat
4. I dont't know to which pin in 8302 goes
5. I dont't know to which pin in 8302 goes
6. [B4] of 8310 goes to the heater of the seat but also to the backrest
7. [B1] of 8310 goes to the heaterof the seat but also to the backrest
8. GND connected to 8302 and to 8310
9. [B3] goes to the thermistor of the seat
10. I don't know to which pin in 8302 goes
Because I found that pin 6,7 and 3 and 9 goes to the green plug:
And then to the seat, and there is no separate plug which goes to the backrest, I'm assuming that backrest is powered from the same plug.
1. [4] so +12v
2. Empty
wurlycorner
- x 272
Just picking up on this old thread as I need to fault find parasitic drain on this circuit and I want to get the heated seat switches out of the seats, as part of that.
Marc posted the instructions/diagram below (you have to remove the side trim in order to remove the switch
because of how the plug fits into the switch)… It says to release clips a (x3) and then pull the side trim away.
I can release the single front clip and I think the lower of the two rear clips releases by just pulling up, but I can’t see how to release the top ‘a’ clip - in fact, I can’t even see or find that one!
Can someone who has done this (without breaking anything!) please shed any light?
GiveMeABreak wrote: 29 Sep 2019, 16:36 You might need to remove the front seat to get proper access to the seat side trim, then:
Unclip: The side trim (1) ( as "a"), using trim removal tools.
Disconnect the connectors ( as "b", "c").
Remove: The side trim (1).
Unclip the trim (2) ( as "d").
Remove the trim (2).
Iain
CX DTR T2 Safari (silver)
Iain
wurlycorner
- x 272
Managed to get the panel that holds just the heated seat switch and massage seat switch off.
It’s not ideal (it’s not meant to be removed this way) and it did bend a couple of the tabs unfortunately, but without breaking them…
You can reach the front clip with a hand between the seat squab cushion and the side of the panel, depress that with your finger (don’t press too hard or it will break) and that will lift the front out slightly clear from the side panel.
Then slide a plastic trim tool in (vertically) at the front in the gap you have just created and slide it along towards the back, to pull the inside of the side panel away from the panel, towards the seat squab, which completely releases the inside of the panel from the seat side trim. You cannot depress the rear tab with your fingers, peeling the side trim away from the panel is the only way it will work.
The outside of the panel is then still held in place by two clips lower down nearer the door, but it is possible to free it by tilting it away from the seat squab (towards the door opening) and reaching up behind the side panel on the seat to release the clips. Those clips are VERY thin so will likely bend unfortunately, which means they won’t hold it tightly in future.
The wire to the heated seat switch is ridiculously short, basically no slack.
A few pics below in case others find it helpful.
Iain
Iain
