Citroen C5 Ng4 radio signal problem
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
gu243cH
Unread post by gu243cH »
Hello everyone! I have a problem with the signal of the radio. The cars two back radio modules do not get any power. I do think that the rear window was changed at some point so I don't now exactly where to apply the power cable for the modules. ( FM 1 and FM 2). I would like to know which is the plus and minus from the power cable. The car in question is a 2011 Citroen C5. I will attache a photo with the cable. Thanks in advance!
x 6945
Re: Citroen C5 Ng4 radio signal problem
Tourer or Saloon?, With or without Services Module?, with or without Equaliser Amp?
gu243cH
Saloon, the others I don't know
Reason: Image rotated.
x 6945
Ok, so the wiring diagrams do not show the wiring connections - only the coax. So you need to get me a good clear picture of the top of BOTH the aerial module labels. Then I can identify the part correctly.
gu243cH
Here are the pictures, I hope that's ok.
x 6945
Ok, so I've completely misunderstood you. I thought originally that you had no wires going into the back of the aerial modules from your first picture showing the disconnected wiring harness - now from these latest pictures, I can seen that the wires are already connected there.
So are you saying that everything is connected up, but that there is no power? If that is the case, you'll need to trace the harness back. I cannot locate any wiring from the Aerial modules apart from the COAX cables. So I can't tell you were the power cables come from. But this picture may help you trace the wires back from the Aerial modules in your picture to the other connectors which should be behind the rear screen pillars and the rear quarterlight pillars:
I hope that helps a little.
gu243cH
I solved the problem. Thank you very much for your help.
x 1940
What did you do? We'd all like to know!
