Not using car for longer period
zeeshanzaki
x 6
Unread post by zeeshanzaki »
After fixing c5 v6 2001 it was almost end of registration. I already bought another car and dont want to register for another year. What is the best practice to keep car in working conditions without driving. I want to use it after a year and dont want to spend thousands to make it roadworthy.
x 1751
Re: Not using car for longer period
- Keep battery charged, either every couple of months if disconnected or off the car, or with an intelligent charger if left connected. The latter is best.
- Lift the wheels off the ground, to prevent tyres acquiring flats.
- Leave parking brake off, if you can.
- Shade tyres from sunlight.
- Make sure there is new/good condition coolant in the engine.
- If possible, allow some ventilation for the interior.
- Lift wipers clear of the glass (wine corks under the arms) to prevent them setting at an angle.
- Don't start the engine up for a brief run too often - it's not good for it; two or three times in the year is more than enough. When you do, allow to run for 10mins or so, to get some temperature going.
- Talcum powder the door surround rubbers; stops them sticking to the bodywork.
moizeau
x 429
Unread post by moizeau »
And make sure it's got some top quality fuel of additive in.
Pete
x 1456
Unread post by xantia_v6 »
My cars (including 2 with ES9 engines like yours) always sit for 6 months at a time. My XM sat fro 3 years before I bought it, and required nothing more than a new battery.
If stored in a dry garage, then battery and tyres are really the only things that should deteriorate in a year. If storing outside (in the UK), then park on a dry waterproof surface to keep the humidity under the car as low as possible, or at worst, put a waterproof tarp under the car.
It is better to change the engine oil before storage, as sediment will fall out of suspension and form a sludgy layer, not only in the sump, but also in the oil ways.
I have never had a problem with old petrol in a modern engine, even when sat for 15 years in a vented fuel tank, but would advise leaving the tank at least half full.
x 2941
If it's a manual fix the clutch pedal down to stop it seizing the plates together.
x 1751
Gibbo2286 wrote: 22 Mar 2020, 10:03 If it's a manual fix the clutch pedal down to stop it seizing the plates together.
Would advise against that - puts an enduring strain on the clutch cover fingers.
Just a thought.
x 3306
Would firing her up and driving her a few yards back and forth every couple of months help to keep things moving and in good order? This would be DRIVING her, not PUSHING her, so the gearbox also gets to work.
x 2941
white exec wrote: 22 Mar 2020, 11:00
Just a thought.
It was common practice in the export market, clutches and gearboxes were destroyed by clutch plates being stuck to flywheels and force being used to release them.
x 1751
OK, didn't know that.
x 1751
Hell Razor5543 wrote: 22 Mar 2020, 11:05 Would firing her up and driving her a few yards back and forth every couple of months help to keep things moving and in good order? This would be DRIVING her, not PUSHING her, so the gearbox also gets to work.
Not a bad idea. Hydraulic Citroens don't thrive on being left to stand for months/years.
What does need to be avoided is just starting up the engine, leaving it to idle briefly, then switching off.
Most wear happens immediately after start up of a cold engine.
Driving a mile or so would be a good idea, if that's possible/legal, otherwise just - as suggested - a bit of shunting around.
If all impossible, not irretrievable - just look after battery and tyres. :)
x 3306
So I would suggest also doing a Citrobics session as well, then?
x 1751
Definitely. Always forgetting the obvious. :gt:
zeeshanzaki
x 6
Thanks everyone for you advise.
I have 80 meter driveway so I can drive on my driveway, but I will cover it up properly and disconnect the battery. The car issitting now since 4 month and when I started it always started first time after two month it started without any issue.
Skull
(Donor 2026)
x 379
Unread post by Skull »
Hindsight is a wonderful thing ....in addition to the above recommendations
I was thinking mine is stored outside so I think the best I could do is a heavy duty tarpaulin on the ground, what does everyone think about some logs cut to say clear the subframes when set to high, then lower the suspension to low, that would release the majority of the weight from the road wheels, release most of the hydraulic system pressure as well :?:
Gary
Skull
(Donor 2026)
x 379
Strangely when I done my first clutch change on a Triumph TR7 it sat for a month or so after the change, before I attempted to drive it properly and the pedal had already gone solid (hydraulic slave) I was adamant it should work as it was brand new, I tried freeing the pressure plate from the clutch plate or the clutch plate from the flywheel by pressing as hard as I could on the clutch pedal until it finally moved - well the clutch line split anyway :oops:
I had to fully remove the gearbox again and after removal of the pressure plate the clutch plate was tacked to the flywheel, it released it's 'grip' with a prod of the finger :twisted: obviously some of the grip had already been removed when the pressure plate was removed.
Laugh about it now :rofl2: but at the time it was #-o
Gary
