New owner 2009 207 1.4 thermostat/temp sender question
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Re: New owner 2009 207 1.4 thermostat/temp sender question
Waited for 6 hrs or so so engine was cold, just gone out and started it up and left it on idle for 10 mins, both top and bottom hoses are heating up at same temp to touch wise.
Normally that would suggest to me stat is wide open, not sure on this engine due to sensors
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Are you over thinking this Colin? There are backup modes and warnings if things are not right, including fans engaging at speed if there is an overheating situation and cutting out of the A/C compressor. Unless the car is not performing, or throwing a wobbly, I would leave it until there are symptoms of a problem to be honest.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The software is Diagbox, used by PSA. It has the ability to graph live data on many of the vehicle's systems.
- My Cars: 307 RESTYLING ESTATE - LEISURE 2.0 i 16v 143 (EW10A) Manual gearbox 5
- x 4
OH ! didn't have seen this menu on my diagbox.. when i reassemble my car i'll take a look. Do you know if it also log the data , to analyse it off the car ?GiveMeABreak wrote: ↑17 Feb 2020, 10:57 The software is Diagbox, used by PSA. It has the ability to graph live data on many of the vehicle's systems.
- Donor 2023
Now would i do something crazy like that
Actually i believe i was not thinking full stop to be honest. Thinking about it all the symptoms point to a faulty stat, and if its reference value to open is -40 degrees then it should be fully open all the time
As the boy wants it right he has ordered a new stat and temp sensor from main dealers, his money
Colin
- Donor 2023
David the non graph screen shot is the where you can access the graph live data screen. On my screen in the bottom right hand corner i have 2 icons a pause icon and a graph icon, click on the graph icon and hey prestoDavid_CH wrote: ↑17 Feb 2020, 16:42OH ! didn't have seen this menu on my diagbox.. when i reassemble my car i'll take a look. Do you know if it also log the data , to analyse it off the car ?GiveMeABreak wrote: ↑17 Feb 2020, 10:57 The software is Diagbox, used by PSA. It has the ability to graph live data on many of the vehicle's systems.
AFAIK yes it creates a log that you can go back into and look back over off the car on the laptop that Lexia is installed on, i just do not have the tech know how to save/print the log file so i can post it here, i have to take a photo lol
Colin
- white exec
Agreed.admiral51 wrote: ↑16 Feb 2020, 21:35 Waited for 6 hrs or so so engine was cold, just gone out and started it up and left it on idle for 10 mins, both top and bottom hoses are heating up at same temp to touch wise.
- white exec
I'm guessing that the gauge on this engine is driven from the engine ECU, rather than having its own sensor/sender. Is that correct? I ask, because this is typical of an out-of-spec Gauge sender.admiral51 wrote: ↑15 Feb 2020, 16:56 The problem is that until engine temp got to 65 or so the gauge was not moving, then it decided to play catch up, finally matching engine temp at 76 degrees then over reading to 90 when engine was showing 80.
It then behaved and stayed at 90 until fans kicked in and dropped to 80 and then crept back up to 90 when fans had stopped.
- white exec
Never heard of that. Decent standard coolant will protect down to –35°C, and first priority is getting engine/heater temp up to working level, and maintaining it. Even a tiny crack/leak/opening of a 'stat can cause engine/heater temp to plummet in cold conditions and light/normal throttle.
- Donor 2023
I believe the temp gauge is driven by a stand alone sensor on the thermostat housing and is actually doing its job with the live data confirming it reading engine temp correctly.white exec wrote: ↑17 Feb 2020, 17:49I'm guessing that the gauge on this engine is driven from the engine ECU, rather than having its own sensor/sender. Is that correct? I ask, because this is typical of an out-of-spec Gauge sender.admiral51 wrote: ↑15 Feb 2020, 16:56 The problem is that until engine temp got to 65 or so the gauge was not moving, then it decided to play catch up, finally matching engine temp at 76 degrees then over reading to 90 when engine was showing 80.
I am guessing the engine ECU uses a separate sensor for its coolant temperature reading but again i could be wrong as usual.
Disregard my idle thoughts about minimum temp stat opening, it was all down to me being confused over the -40 degree temp reference value, figured out if the stat has an opening value of - 40 degrees it will always be open
- white exec
Senders common to many engines
- green one for Injection/Engine ECU
- blue one for Gauge
- brown one for cooling fan operation
This is reduced to two on some engines, with Engine ECU taking over functions of one of them.
Exact circuit diagram will confirm.
- Donor 2023
In that case Chris you are right and wait for it ............ i am wrong lol
Def a Green plug on the thermostat housing
- white exec
Do check the circuit diagram, though. Maybe another sensor elsewhere?
- Donor 2023
Just a quick update on this one
Stat and temp sensor have been replaced whilst i have been away this past week, temp gauge is now showing in the region of 80-90 and bottom hose is staying cold until upto temp.
Tomorrow i will attempt to check the bleed process has been done correct with the engine below the stat opening threshold and trying to tell the ecu to open the stat, warm top hose cold/bottom hose i should get a warm bottom hose if the stat is tricked into opening ?
On a side issue if anyone has a little spare time and access could i have the wiring diagrams for the rear speakers for said car as both are not working, not sure if it is a head unit issue but guessing it is wiring related
Colin
Colin
