I'm having a 'mare with my Citroen Relay and would hugely appreciate your thoughts. I'm in France and working through this with my local Citroen dealer, who we've know for 30 years.
I'll describe the symptoms and the work done thus far...
Symptoms
Dashboard warning lights for Battery and Oil glowing very slightly when ignition is OFF.
Likewise, the dash lights for Fog lamps and Fuel
All of these continue to glow faintly when the ignition is ON and engine running.
Engine warning light comes on intermittently. Warning is 'oil change'. Oil has been changed and codes cancelled.
On one occasion, during a motorway run, engine went into limp mode.
Starter motor failed, death.
Diagnosis
Electrical earthing issue
Faults found
Front loom - widespread and serious melting insulation damage to wiring in front loom
Starter motor fried
Two gizmos in fuse box fried (don't know what they are in english, mechanic calles them 'roulettes' and they appear as two coloured cubes)
Corroded earth strap
(will post pic of the list of replaced parts)
Work so far
Entire front loom replaced
New starter motor
Earth strap
various electrical/fuse components
And then...
Van then appeared serviceable, collected Friday evening, ran 20km and the electrical faults appeared AGAIN.
I've disconnected the battery so as not to risk frying the loom or starter motor. It's the weekend and my garage is shut until Tuesday, so I've got time to think about this and to ask for your thoughts.
