I've got a 57 plate C5 saloon.
The reverse sensor is not working.
Spent £20.00 on a diagnostic and nothing showed up.
So apparently it's either a fuse or the module.
Where is the fuse for the reverse sensor situated?
Everything else concerning reversing works fine.
Reverse sensor
- x 1485
- x 6955
Re: Reverse sensor
It will be a MK II.
Then your diagnostic device probably isn't cutting it - only a decent bit of kit can read all the constructor ECUs.
If it is a faulty sensor, then it WILL give a fault code to a reader than can communicate with the ECU. It will tell you exactly which sensor (if any) are faulty.
A manual test: Switch ignition on, put in reverse gear, walk round to the rear and lightly place a finger over each sensor - you should feel a tingling or a slight pulsing - if it does then that sensor is working. But no substitute for a proper diagnostic. Also check in the boot area to the right of the spare wheel - the parking assistance ECU is mounted there. Check to make sure you haven't had a liquid spill onto the ECU or that it's been knocked.
There is a known issue with the rear sensors on the MK II in that water can get splashed up and run down the sensor wiring into the sensor where it stays and this will cause water damage eventually. I had to have 3 replaced because of this. I then got the techs to re-route the wiring and tidy it up so that any water would run away from the sensors.
Forevertonian
Re: Reverse sensor
Thanks everyone.
The vin number is VF7**************[VIN obfuscated, can be read by forum staff]
Reason: VIN updated
Reason: VIN updated
- x 1485
Re: Reverse sensor
Nothing showing against that VIN for parking sensors, so it must be an aftermarket system - you will need to trace the wires back to find the ECU/ fuse.
Forevertonian
Re: Reverse sensor
Oh blimey.
Thanks for that.
Thanks for that.
- x 1938
Re: Reverse sensor
That VIN must be slightly wrong as it hasn't been masked. Maybe the correct VIN would show something?
- x 1485
Re: Reverse sensor
Thanks Paul should be hidden now? The last 8 digits were right, which is all I normally input, there was an extra R after the 7 which overrode the filter.
- x 6955
Re: Reverse sensor
Ciroen did sell their aftermarket kit - I had one fitted on a MK I C5. It was an audio unit with red bulbs that was fitted at the rear edge of the headlining. It was directly fed off the reversing light wiring, no ECU - so maybe it is one of these.
- x 1056
Re: Reverse sensor
First things first, are the reverse lights working?
- x 3303
Re: Reverse sensor
And do you hear a 'bong' noise when you put her into reverse? If the lights don't work and no 'bong' it is probable the reversing switch has failed. This would then have the knock on in the sensors not working either.
- x 5670
Re: Reverse sensor
My bong is only intermittent
Forevertonian
Re: Reverse sensor
All lights are working at the rear.
It's got an ESP switch on the dash.
